Old 11-17-2004, 09:29 PM
mv520 mv520 is offline
Question Audio Troubles for me
I'm having trouble hooking up the wires to my Pioneer DEH-p3500 to my car. I bought it from a friend because his dad got in a wreck and it was hisI found 2 diff diagrams(3 actually) and im confused.
Mobile Audio / Video
Battery RED + (+) IGNITION SWITCH HARNESS
Accessory01 ORN + (+) IGNITION SWITCH HARNESS
Ground BLK - (-) RADIO HARNESS
Illumination GRY (+) RADIO HARNESS
Dimmer BRN (+) RADIO HARNESS
PowerAntenna PNK (+) RADIO HARNESS
FrontLeftSpeakerPos TAN
FrontLeftSpeakerNeg GRY
FrontRightSpeakerPos LT.GRN
FrontRightSpeakerNeg DARK GREEN
RearLeftSpeakerPos BRN
RearLeftSpeakerNeg YEL
RearRightSpeakerPos DK.BLU
RearRightSpeakerNeg LT.BLU
Amp NOT LIKELY
Control Modules
Yellow- ignition switch
Orange- 12v all times
Brown- tail light dimming
Black- ground
Left front speaker- grey and tan wires
Right front- Dark green and light green
Left rear- brown and yellow
Right rear- dark blue and light blue
The front speaker wires should be on one connector, the rear speaker wires should be on another with the power wires on their own.
There are 2 black wires, both are ground
There is also a brown/white and another grey wire that are used for the adjustable dimming(dimmer switch)- I don't know if a replacement radio can use these
Im just plain up confused... I have a 92 Lumina Eurosport
http://members.boards.ie/mv520/CA1.JPG
Car Wires
http://members.boards.ie/mv520/CA2.JPG
CD player wires
http://members.boards.ie/mv520/CA3.JPG
CD player.
Anyone an expert on this ? if not how much does Best buy charge for installation.
Old 11-18-2004, 01:10 AM
PepeLuche PepeLuche is offline
Have you tried with a test lamp? i mean, if you dont really know how your wires are, try with a lamp, first identify the DC, ground and remote or ignition. Afterwards with a battery like a double AA, try to find out your speakers.... a little bit trick but it works, Good luck.
Old 11-18-2004, 06:23 AM
jeffcoslacker's Avatar
jeffcoslacker jeffcoslacker is offline
Lactose the Intolerant
Re: Audio Troubles for me
You can go to Best Buy and get an adapter harness that will make the factory connections plug right into that unit, without trying to figure out what every wire is for. They are usually only $12-15.
You made three mistakes. First, you took the job. Second, you came light. A four man crew for me? F**king insulting. But the worst mistake you made...
...empty gun rack.
Old 11-18-2004, 06:25 AM
You probably know this, but make sure that unit is grounded BEFORE doing any connecting. That will protect it from damage.
...empty gun rack.
Old 11-18-2004, 02:13 PM
dwalmop dwalmop is offline
I agree with Jeff, go to best buy and buy the wiring harness. This will save you A LOT of headaches, Then, you can literally just plug in the pio to the stock harness.
Old 11-19-2004, 11:17 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Or you can go to this website, that is if you already chopped into your factory wire harness. http://www.corvetteradios.com/Page.html
