Old 11-17-2004, 08:59 PM
chevyguy93 chevyguy93 is offline
newb> ABS
I'm a newbie to cars, as this is my first. it's a 93 4 door cav. My problem is that my ABS light stays on. I have no trouble with my breaks, because they work fine. I was told that it might just be dirt on the sensors, and if i cleaned them off really good, it should go away. Now, can anyone help me and tell me what to do, such as where are the sensors located? I know as much as taking off the tire. What do I do next? hehe.,
Old 11-17-2004, 09:30 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Re: newb> ABS
Are you gettin a check engine light?... You might need to have the code taken out.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 11-17-2004, 09:32 PM
DXJ DXJ is offline
Re: newb> ABS
Check the plugs and wires to the ABS unit and the sensors, check the fuse, and if you can locate the wiring harness plugs the ABS uses, check them also. There is some information in the repair manuals, but detailed troubleshooting requires special equipment.
Old 11-17-2004, 09:34 PM
Re: newb> ABS
No im not getting a check engine light, just the ABS light.
Thanks for the replies
Old 11-17-2004, 10:13 PM
Lifted GMT-360!
Re: newb> ABS
well here is a quick test... disconnect your battery from the terminals.... let it sit that way for 30 -45 min.. it will dump the computers short term memory, and will put that code to the side... if your light goes off... then that was the problem.. Take is somewhere and have the code properly taken out.. then if it occurs again, check fuses and connections...
