Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 11-17-2004, 09:41 PM
arnstr arnstr is offline
plastic coolant connector braking twice
92 buck lesabre
plastic coupling that connects engine block to the water pump
(via rubber hose) broken
dug out the piece stuck in the block and replaced the coupling
ran for 10 minutesd or so and checked for leakage
the wife drove to work next morning (10-15 Km) and it broke again
maybe thermostat is stuck and the piece is melting??
tightened the plastic coupling too much (I don;t think so)
air in system when refilling coolant??
bad sensor??
anybody have similar problem and what is the cause??
Old 11-17-2004, 11:41 PM
public's Avatar
public public is offline
Re: plastic coolant connector braking twice
I have replaced several of these over the years with a copper nipple and just ran hose. I believe Dorman makes the nipple with the propper thread on the base. Good Luck.
Yes, I am retarded.
Old 11-18-2004, 10:29 AM
avatar307's Avatar
avatar307 avatar307 is offline
This is apparently a very common problem, and a very poor design on GMs part. (Especially since it's under the alternator, so you never know it's broken until it's REALLY broken.)
I bought a steel fitting at AutoZone to replace this exact same piece. However, AutoZone doesn't list it in the computer as being associated with the car and no one was really sure what I wanted when I showed them the remains of mine.
I ended up following the guy into the back, and digging through a drawer of heater hose fittings. There was a single black steel one, with an O-ring on it, which turned out to be an exact thread match for mine.
However, they do list the hose in computer as Radiator Hose - Bypass or Heater Hose - Bypass, made by Kelly-Springfield I think and listed under Radiator Hoses.
Hell... here... let me find the receipt. (This whole issue here aggrivated the hell out of me, so let me see if I can save someone else the trouble.)
For my 1995 Buick LeSabre, 3.8L V6 SFI VIN:L engine, my reciept reflects I purchased the following from AutoZone:
#246410 563590 HTRHOSEFTG 5/ $2.99
#002385 S-3041 BY-PASS HOSE $4.99
#268409 KE12SS CLAMP 9/16" T $1.49
Translation (my best guess):
Item Number: 246410 563590
Description: Heater Hose Fitting - 5/8"
(I'm guessing it's a 5/8" thread. My reciept only shows the 5/, but it can't be 5/32" or 5/16", as is was a pretty large fitting.)
Item Number: 002385 S-3041
Description: Radiator Hose #3041 (Bypass)
(3041 is printed on the label wrapped around the hose.)
Item Number: 268409 KE12SS
Description: Standard 9/16" Hose Clamp x 2
Hope this info helps save you some considerable time and fruastration. Remember, these parts are for a 1995, but I'm betting a 1992 uses the same.
As far as getting the old plastic piece out of the engine. I ended up using my pocket knife as a make-shift extractor (as they don't make extractors that big). Hammered it in with my Mag Light and then torqued it with a screw driver. For the most part all I accomplished was scrapping out the inside until it finially broke. Then I was able to pry the side with a flat screw driver while pulling with my finger in the middle of the remains of the fitting.
Hey... I was in the AutoZone parking lot when the fitting finially broke, so I only had 4 screwdrivers, a knife, a flash light, and two sockets sets to work with. LOL
I had been tracking a coolant leak for months, and was at AutoZone to buy a second water pump gasket. Opened my hood, and there was a stream of coolant shooting out from under the alternator. I nearly threw something and jumped for joy in the same stream of cussing. Spent 3-4 hours under my hood in the AutoZone parking lot.
"Sleeping is the only thing keeping me from killing all the stupid people on this planet."
"Of one that loved not wisely but too well;" (Othello, Act 5, Scene 2, Line 344)
Old 11-19-2004, 07:52 PM
piewagn's Avatar
piewagn piewagn is offline
You can buy a new design metal nipple from you local GM dealer.
I've been working on Buicks for 20 yrs. I've done several of these repairs.
Same goes for all the C/H platform vehicles with the 3800 eng.
Old 03-19-2005, 12:14 AM
charston charston is offline
Got a nice heavy metal one from GM in '03.
I got the old one out with a wood (spade) drill bit and a cordless drill. It was broken off flush so I jammed the points of the bit into it and squeezed the trigger. Came right out.
Old 03-19-2005, 04:17 AM
TTCzar TTCzar is offline
Yes, the replacement fitting from your GM dealer is nice, but $19.00 nice? That's what I donated for mine. I need another for my other LeSabre, I'll try the AutoZone stock number. Thanks for posting that.
Old 03-19-2005, 11:16 AM
LeBuick's Avatar
LeBuick LeBuick is offline
Re: Re: plastic coolant connector braking twice
What a bitter sweet blessing. While saving you hood time changing out a good water pump it left you stranded at the parts store.
Old 03-20-2005, 12:36 AM
lesab92 lesab92 is offline
I replaced our 92 fitting with GM
While changing out the alternator in our '92 Lesabre last year, I noticed some coolant below where the old plastic piece threads. I discovered that the piece was already half broken. I bought the GM replacement which came with a nice 'O' ring at the end. I had some trouble getting out the old part, but have had no problems since changing to the metal part. So how much $$$ did GM save by using the plastic part? I heard from the parts guy at a GM dealer that others had this piece fail while doing 60 MPH. To me it's just another example of ridiculous engineering. Use a plastic part on the cooling system where it can fail, but apply mirror finish stainless steel trim to the lower body of Park Avenues. Too much trim and not enough logic where it is really needed. I really don't think I'll be buying any more GM cars.
Old 04-23-2007, 02:29 PM
duff2 duff2 is offline
Angry Re: plastic coolant connector braking twice
All I had to do was show it to a GM parts guy. I said "you probably know what this is". He said "do you want a hose too? I asked "It's not a $30 hose is it? ". He said no about $8. It was a $13.35 hose. But I really got hosed when I got the bill. The steel connector was $15.97. Don' buy it at a Stealership !
Duff
Old 04-23-2007, 08:56 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Duff
Welcome again to AF, and thanks for posting! This thread is outdated and should not be resurrected.
Please read: Posting in closed or outdated threads
Closed Thread
