Go Back   Automotive Forums Car Chat > Honda > Integra
Old 11-17-2004, 08:51 PM
floppymoppy1234 floppymoppy1234 is offline
Send a message via AIM to floppymoppy1234
integra engines
hi im a bit confused about which engine is in which car and their hp... correct me if im wrong but i thought that:
rs/ls - b17 140-145hp ?
gsr - b18a/b 160-180 ?
type r - b20c 190-210?
thx
Old 11-17-2004, 09:38 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: integra engines
RS, GS, LS - B18a/ B18b 130hp/142-145hp respectively
GS-R - B17a1 ('92-'93 GS-R)/B18c1/B18c 160hp/170hp/180hp respectively
Type R B18c5/B18c R - 195-200hp
Someone might want to check the hp rating on the b18a, I may be off on that one.
Old 11-17-2004, 09:53 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: integra engines
not even close
86-89 D16A(?8?) DOHC D series power I dont know
90-91 B18A DOHC non VTEC 130HP/125 ft/lbs
92-93 B18A DOHC non VTEC 140HP/126 ft/lbs
92-93 GSR B17A DOHC VTEC 160HP/117 ft/lbs
94-95 B18B DOHC non VTEC 142HP/126 ft/lbs
96+ B18B DOHC non VTEC 140HP/126 ft/lbs
94+ GSR B18C1 DOHC VTEC 170HP/128 ft/lbs
97+ ITR B18C5 DOHC VTEC 195HP/129 ft/lbs
B20's are CRV engines.
I know some of the torque specs are a bit off but real close
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 11-17-2004, 09:54 PM
94tegRS's Avatar
Re: integra engines
was responding to first post, not you civicspoon
current
history:
Old 11-18-2004, 12:21 AM
integrawhat integrawhat is offline
Send a message via AIM to integrawhat
Re: integra engines
can someone post a reliable link to where there getting 170 for the usdm 94^ gsr i have always been told it is 180 for the b18c1 and 185 for the b18c and the jdm has the xtra hp from 10.6:1 c/r as opposed to 10.1:1 for the usdm this is what i read over and over when i was looking for my engine?
A.K.A. GOT WIDE
darton 84mm MID's ls stroke 2.0l GS-R
pnp head with full skunk2 pro series valve train
and pro1 cams
custom divided top mount w/garrett gt4094r
not stoping till i hit 750hp to the wheels
this aint your mom's car so DONT F***ING TOUCH IT
Old 11-18-2004, 12:42 PM
CivicSpoon's Avatar
There is no Spoon
Re: Re: integra engines
I believe hmotorsonline sells the USDM motors as well as the JDM, looks like they are the same price though. But B18c1 is actually the engine code for the USDM version (170hp), the JDM one is just b18c (180hp). And the B-series with the 185hp is the 1.6L Civic Type R motor (b16b), which is a destroked Integra Type R motor (b18c5 aka b18c R). Again, hmotorsonline has the hp and tq readings from each of the motors. But if you mean the specific difference in each motor (internals) that gives the JDM motors more hp, then I really don't know of any site. It's usually just slightly higher compression, little differences in the ECU, and sometimes slightly different cams.
