Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-17-2004, 04:59 PM
97GreenEclipse 97GreenEclipse is offline
Turbo Is Puttering Pls Help!!!
Well ok lemme start off with this, I have had no problems with this car at all until now.. It's not spark plugs or anything like that I have figured this one out , however when I get to about 5000 rmp and rising it seems like my turbo stops spooling fully and u hear a whistleing noise..
Now my question is what could be causing this?? the turbo isn't blown ive had one of those b4 and we all know how nasty that looks :P pls can u help me i need to figure this out thx a lot
Keep in mind my BOV is working correctly and realeasing pressure and it seems ok but the noise and the spool thx again :P
Old 11-17-2004, 07:40 PM
1stGenRocks's Avatar
1stGenRocks 1stGenRocks is offline
Send a message via AIM to 1stGenRocks
Re: Turbo Is Puttering Pls Help!!!
im guessing you have your stock 2g bov? if you do that sound is your bov leaking once your boost goes up. it will still function properly to release pressure spikes but the 2g bov leaks all the time. get a 1g bov and your problem should go away. if you have a new bov already then you probably have a boost leak, check vfaq.com for how to make a leak tester
-1stGenRocks-
95 Tsi AWD: 6 bolt, DSMLink, 880's, ACT 2600, lightweight flywheel, AGX's, Dropzone springs, poly motor mounts and suspension bushings, 3 inch turboback, gus modded 1g BOV, hardpipes, drilled & slotted rotors, 17's
plans: bastard 20g, water/meth injection NO FMIC
Old 11-17-2004, 08:11 PM
joemathews's Avatar
joemathews joemathews is offline
Boost drops off on a T25 soon after 5000 rpms anyway . You probably just have a boost leak making things a little worse.
If you are really concerned, you can wait for your car to cool off sometime and then take the intake pipe off of the turbo inlet and check the shaft for up and down, left to right and in and out play.
1996 Eagle Talon
Old 11-17-2004, 09:19 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
typical t25. all grawl, no bite.
DSM geek
Old 11-18-2004, 05:16 AM
damn it
well i have a greddy type s BOV, as far as my turbo goes it's a garrett T28... soooo is this still gonna be the problem???
Old 11-18-2004, 09:41 AM
boost leak
DSM geek
