Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-17-2004, 04:54 PM
fctrent fctrent is offline
Question rear passanger door won't open-auto lock works fine
1995.5 rodeo---rear passanger door wont open--inside or outside
can the handle be accessed when door is closed?
a clip or bar must have fallen off or loose--can it be reattached
is there a quick fix or dealer service item?
auto locks go up and down just wont release lock
am i screwed?cant get door panel off when closed--will a slim jim work---must be seperated @ latch--both rods must have fallen off--accuator works fine
anybody have a diagram of locking mechinism?
Old 11-17-2004, 07:57 PM
megavolt121 megavolt121 is offline
Re: rear door won't open-auto lock works fine
Suggestion is to buy another rear door panel(the plastic), then cut or pry yorus open.. unless someone else has an idea of how to get inside the door.
Old 11-18-2004, 01:37 PM
iskiuskiweski's Avatar
iskiuskiweski iskiuskiweski is offline
Send a message via Yahoo to iskiuskiweski
Does it have the seperated window? I am having some occasional trouble with mine as well, but it maybe different. Mine has to do with the window release mechanism. It is like it doesn't know that the window is up so it won't let you open the door portion. If I press the button that releases the window a few times then the door will finally open. Don't know if this is similar to yours or not, but it is something that I have observed.
98 Rodeo S/LS 3.2L V6 Auto 4WD 150k
