I was driving my 1996 Peugeot 306 Dt, suddenly I have noticed that the a\c wasnt working any more. I have tried all the fuses but they were all good. I think that the problem is the a\c knobs panel, from this panel I have changed a faulty DIODE k600 60amp which was acting as open. A\C back light works, but blower/ac/heater doesn`t work.
Any suggestions? The mainboard of the panel has the following part number: GKR 9 140 012 237 E13. The part number of the whole a/c compartment is GKR 9 140 010 209. Thanks in advance. |
HELLO,firstly when you switch the a/c on do you hear the compressor click in the engine when the engine is running?if not then the compressor is not activating because the a/c is out of gas due to a leak or the low pressure switch isn't working..but i would go with the first option.Is the a/c switch in the car the one you're talking about or the fan switch/turning knob not turning?if it is the later,that has nothing to do with a/c.
Basically if you have no cold air coming through your vents when you switch the a/c on then you are out of a/C GAS. GOOD LUCK! |
Re: A\c Panel Not Working
When i am switching the a/c, the compressor doesnt start. Even the fan/heater doesnt work. I think the problem is from the panel where the knobs are installed. what do you think?
Thanks In Advance. |
have you been able to resolve this problem? Mine now has the same problem and I am thinking along the same lines, that the control panel is faulty.
if only it would work |
