| Off-Topic Talk about anything other than cars. |
bbk 62mm throttle body for my 95 tsi
will this be better then my stock throttle body?
Re: bbk 62mm throttle body for my 95 tsi
if you use a 62mm tb you will need to port out the throddle plate going into intake manifold, if not port out the intake manifold. there was a decent thread about that on dsmtuner not more then a week ago.
DSM geek |
cool post the link to it if you can.just incase i cant find it
yeah post it if you have it, I have one too and my manifold is ported...
Are you serious? "Is a larger throttle body better than a smaller one?" YES. The answer is that it's better. It's not a good buy though, considering a 1g TB is 60mm, a huge increase over 2g stock. I wouldn't worry about 2mm in the throttle body on a stock manifold.
I have a 3000 gt TB and it bolts right up to the manifold. In fact it looks 99.5% just like the Eclipse aside from some lil things here and there. The TPS even mounts the same. The opening is like 63/64mm the last I checked. Is that a little much?
well there is a 1g manifold on my car does that mean they usually use the 1g tb along with it?
DSMers are breaking BBK, accufab, ford, edlebrock, and other throttle bodies more often than I snap input shafts and take pistons apart. I would highly NOT recomend it unless you are aware of all the actions required to help it live more than a week. Not worth the effort in my opinion, hence the reason I run a 60mm 1G NT throttle body on my car.
Kevin Jewer RWD Talon - 7.92 at 180 Mightymax - 10.7 at 125 |
Re: Re: bbk 62mm throttle body for my 95 tsi
hey kevin are those 1g nt tbs the same as the turbo ones? all you gotta do is replace the throttle body seals with the turbo ones right. maby the biss oring also? probably help out anybody wanting to swap a 2g tb for a 1g tb.
They are the same except in the UICP connection. The NT does NOT use a TB elbow like we are used to, it has a 2.75" inlet that you clamp a coupler to. Thats why I went to it, works well with my 3" UICP. But you are right on all other points mentioned.
