Go Back   Automotive Forums Car Chat > Honda > Let's get Technical!
Let's get Technical! Discussion for hardcore in-depth motor heads!
Old 11-17-2004, 12:47 PM
shizam shizam is offline
Rough idle on 2000 Civic
Thanks in advance for any help on this.
Car was running smooth, then I got a tune up. That consisted of new spark plugs, wires, distributor cap. Then it started running rough. To make matters more confusing I also had an "oil issue" and had about 3/4 a quart too much in the car.
I drained the oil to the correct level, brought it back to the shop, they said the spark plugs weren't in there hard enough and it started running fine.
Next day it's rough again.
I changed the spark plugs again myself, and it ran fine for about 3 minutes, and then started going rough.
Any ideas? The car sounds like a diesel, and you can feel the shake in the passenger compartment. No Tachometer so I can't say what the RPM's are doing.
Old 11-17-2004, 12:53 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
Re: Rough idle on 2000 Civic
bas gas??
are the wires the correct reach? cut the spark will jump between wire to plug if close enough and maybe a few minutes of runnin gvibratesw em out a bit but just enough so you lose one cylinder. not sure why that would make it sound like a deisel but bad gas would.
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 11-17-2004, 12:56 PM
Re: Re: Rough idle on 2000 Civic
Originally Posted by 94tegRS
bas gas??
I'm not sure how to tell if the wires are the correct reach, they look fine to me. I'm almost 100% sure it's not bad gas since I've filled up twice since then and even put in 93 octane.
I did put in some BG44K cleaner to the gas tank though... but that's supposed to make things better.
Old 11-17-2004, 12:58 PM
Greenblurr93's Avatar
Greenblurr93 Greenblurr93 is offline
Kind of a Big Deal
Send a message via MSN to Greenblurr93
could be a stripped spark plug hole, like if when the shop torqued the plugs they tourqued them too much and stripped the hole, which would cause the plug to back out again, which accourding to you fixed the problem before
