Go Back   Automotive Forums Car Chat > Ford > Contour
Old 11-17-2004, 12:10 PM
opaque1997 opaque1997 is offline
Angry Burning Plastic??
HELP!
I have a '98 Ford Contour - My heat blower works sparadically - I can hear it blowing into the console sometimes if it is not blowing out of the vents - then this morning it was running odd - I don't really know how to explain it but I could hear clunking maybe? - When I got to work I noticed a strong plastic burning smell and opened the hood - smoke was coming from the passenger side of the engine - suggestions?
I think this may be a FOrd recall HOWEVER - I have talked to Ford and they deny this - HELP!!
Old 11-17-2004, 10:37 PM
UPDATE!
I have found out that my AC compressor seized up - I am hoping that I can bypass it by getting a smaller - shorter belt - anyone ever done this?
Old 11-18-2004, 07:09 AM
pre98zetec's Avatar
pre98zetec pre98zetec is offline
Send a message via AIM to pre98zetec Send a message via MSN to pre98zetec Send a message via Yahoo to pre98zetec
Re: Burning Plastic??
yea just go to autozone or whatever and ask for a belt to bypass the A/C
-Josh-
96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel
98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp.
01' Chevy Blazer, DD.
Old 11-18-2004, 06:16 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
Originally Posted by opaque1997
UPDATE!
yes, if you need a belt, i have a new one that ill sell you.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 11-18-2004, 07:12 PM
Re: Re: Burning Plastic??
Thanks - I am going to check around here -
I assume it is a pretty easy fix? My dad says he can do it - he has changed out clutch's before and so forth so I assume this isn't out of is realm? Anythign special to know?"
Old 11-18-2004, 09:28 PM
pre98zetec's Avatar
If it's the Zetec, The A/C compressor isn't very hard to change.. Gettin it off is about the hardest part. 2-3 hour job max. I've replaced mine before.
-Josh-
