Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-17-2004, 09:23 AM
klc59 klc59 is offline
severe gas smell
I have a 1993 Rodeo & lately it has been putting out severe gas odors.....particularly in idle....you can smell the gas fumes before you even walk up to the car & there are also slight fumes inside the car. Any ideas what the problem might be? I don't notice any leaking gas anywhere, so I'm kinda baffled.
Old 11-17-2004, 03:51 PM
96rodeo 96rodeo is offline
This may not be of any help but it's worth a look:
http://www.automotiveforums.com/vbul...d.php?t=313926
Good luck
1996 Isuzu Rodeo; 4X4; 3.2L; 140K miles and counting!!!
Old 11-18-2004, 09:57 AM
mrprogrock mrprogrock is offline
Send a message via AIM to mrprogrock Send a message via Yahoo to mrprogrock
Your gas cap might not be sealing properly, causing fumes to escape...or you could have a leak in a gas line somewhere. Try to find where the smell is strongest. Check under the hood when its not running and see if you smell gas in there. If you smell a good gas smell in there then I would check around the fuel injectors to make sure they're not leaking. Your fuel pressure regulator may also be bad...I've heard that can cause gas smell as well.
