Go Back   Automotive Forums Car Chat > Ford > Thunderbird
Old 11-17-2004, 02:38 AM
c_j_crew c_j_crew is offline
ABS/Brake Problems
There Is Something Seriously Wrong With The ABS Sysyem On My Car. 88 T-Bird Turbo 2.3 5 Speed W/ ABS. The ABS Light Came On About 1 1/2 Years Ago And Never Went Off. Nothing Else Seemed To Be Wrong At The Time. Then, About 9 Months Ago, The Brakes Suddenly Became Stiff. It Took All My Effort And Strength To Apply The Brake And Slow The Car Down. I've Bled The Brakes Thinking That 1 Of The Lines Were Clogged And Thinking Maybe There Was Air In The Line. Not The Case. I Was Told That It Was Many Different Things. One Mechanic Told Me That The 2 Right Side ABS Wheel Sensors Are Bad Causing The Brake Booster To Shut Off. Someone Else Told Me That If I Removed The ABS Fuse The Brakes Will Release And Become Soft Again. Does Anyone Have Any Ideas Or Solutions?
Thanks,
CJ
Old 11-17-2004, 08:52 AM
thunderbird muscle's Avatar
thunderbird muscle thunderbird muscle is offline
Re: ABS/Brake Problems
I wouldn't remove the fuse with out talking to a Ford tech about it. The sensors being bad could be a good bet, but I don't think would effect normal breaking.
A founding member of HNF car club!
Do you know what it feels like to do an amazing burnout listening to that wonderful exhaust note, Oh you drive a honda sorry dude, but theres hope they still make nitrous oxide!
Racing a Honda is like being in the special olympics even if you win your still retarded!
Old 12-01-2004, 01:08 AM
JonnyRay's Avatar
JonnyRay JonnyRay is offline
Send a message via MSN to JonnyRay
Same thing is happening with me.. My brake petal just became stiff out of no where. My ABS light has been on for a couple years too.
I notice when I turn the key to ignition but before the engine on I don't hear the electrical wheeze sound of the brake pump turning on anymore. Must not be getting power.
I am having a Ford electrical guy come take a look tommorow. I'll keep updated.
Old 12-01-2004, 04:53 PM
flewthecoupe's Avatar
flewthecoupe flewthecoupe is offline
As far as a hard pedal, check all vacuum lines associated with the brake booster for leaks and if you have the means, pull a vacuum on your booster and see if it holds. Sounds more like no power assist from the booster than anything. But then I am not an expert with ABS.
It's not how fast you can go, it's how fast you can get there.
Proper grammar, it's not just for English teachers.
I don't pick on any one person, I treat everyone this way.
My only pleasure is tormenting those people who work for me.
There are no stupid questions, just a lot of inquisitive idiots.
