Terrible Noise
I recently changed my alternator on my 94 lesabre, after doing so this strange terrible noise suddenly appeared. My brother (who knows more about cars than I) said it sounded like the air conditioner was making the noise, but my a/c is working fine. The noise starts when I start the car and continues till I turn it off, though it fluctuates in loudness. Can someone tell me what this could be and what I can do to fix it?
Thanx, p_grasshopper |
Re: Terrible Noise
The alternator may be loose, causing a vibration, and hence a noise, but that depends on the noise you are hearing. Describe the noise as best you can, that way we can help without having to think as much (I have midterms this week and would like to keep my extra thinking at a minimal level). When the air is off, does the noise persist? What conditions cause the noise fluctuations?
1986 LeSabre Limited L67 sleeper ![]() Fully ported & polished, shift kit, CAI, F41 polyurethane suspension, headers & 3" exhuast, |
Re: Terrible Noise
let your wife out of the trunk
Re: Terrible Noise
It's hard to explain the noise..kind of like a loud winding sound that comes from the front passenger side of the car. It doesn't affect the way the car runs, but the sound is loud enough to hear over the radio. The noise is there when the a/c is off or on, and fluctuates depending on speed, but only sometimes.
Re: Terrible Noise
You said that you changed your alternator, the one you put on, was it new, rebuild or used. It sounds like one of the bearings in the alternator is bad. Ask your brother if he has a mechanics stethoscope to pin point the noise.
Re: Terrible Noise
I'd bet it's the replacement alternator as well. Either the wrong model, improperly mounted, or you replaced it with a used one that had bad bearings to begin with.
Take that belt off and grab the alternator pulley. If you pull on it, is there a lot of back and forth play? Spin it with your hand and listen, does it make a noise? Turn it slowly and feel for resistance as it turns. -- Such things would point to bad bearings. For it to be making this much noise, the signs should be quite noticable.
"Sleeping is the only thing keeping me from killing all the stupid people on this planet." "Of one that loved not wisely but too well;" (Othello, Act 5, Scene 2, Line 344) |
Is the belt installed the proper way arond all the pulleys
Why did you replace the alt to begin with? Was it because the noise was present before the replacement? If you had a noise before you replaced the alt, I'll bet your water pump is bad. I've seen guys mistakingly replace the alt when the water pump was noisey. Very common.
Re: Terrible Noise
water pump would be my guess, my moms car was making an AWFUL noise, and a week later, the water pump blew off the engine. (that was fun to fix, belt chunks flew EVERYWHERE, also jammed up behind the pully on the alt.not fun lol))
LeSabre noise
Check a/c compressor bearings
Re: Re: Terrible Noise
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people. ![]() If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno |
