Old 11-16-2004, 09:15 PM
juki_gt juki_gt is offline
oxygen sensor symptoms?
Hi ! i'm wundering what are the symptoms if the oxygen sensor goes bad my 96 grand am gt has 80 000 something km and i havent changed it yet.
Old 11-16-2004, 09:56 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: oxygen sensor symptoms?
It usually cause horrible gas mileage and eratic performance and idle when it goes into closed loop.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-17-2004, 01:22 PM
Re: Re: oxygen sensor symptoms?
hi! thanks for the response formulaLT1 i just changed my spark plugs,wires and gas ,air filter cause i noticed i have bad gas mileage but now that you told me this i think i'll go and change this sensor .Is it expensive ?is it something i can change myself or do i have to take it in and by the way where do you find the oxygen sensor on the car is it visible?
Old 11-17-2004, 01:42 PM
FormulaLT1's Avatar
Fight the powwa!!!
You can easily look up pricing on many site such as www.carparts.com , www.autozone.com . www.pepboys.com and there are many more. As for changing them it depends whiich engine you have how hard it is to get to but they are usually fairly easy. they can easily seen on the Exhaust manifold. You just unplug the harness clip and then use a open end wrench or special oxygen sensor socket(available at most auto parts store's) to unbolt the sensor and then bolt in the new sensor(make sure it has the anit seize compound on it,they usually come new with it on). Good Luck.
John
Old 11-19-2004, 08:25 PM
Igovert500's Avatar
blue + red light magnet
If your O2 sensor goes bad, chances are you will also have an erratic idle, loss of power, loss of mpg, and possibly a check engine light. If you are only seeing a loss in mpg, check tire pressure and fuel filter as well.
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-20-2004, 04:45 AM
FormulaLT1's Avatar
Fight the powwa!!!
That is true tire pressure is normally something that is quickly overlooked when it comes to horrible MPG and OBD 2 systems are quick to set a trouble code for a oxygen sensor that operates out of normal range like most o2 sensor do when they need replacing but seeing as you replaced your fuel filter and if your tire pressure isn't out of tire specs. It very well could be a possible cause.
