97 keyless entry problem
I changed batteries in my keyless pod. They do not work. Do they need to be reprogramed? If so, anyone know the procedure??
Yes, you need to reprogram. Here is the instruction that worked for me:
1. Sit in the driver's seat and lock all the doors. 2. Unlock and open the driver's door. 3. Insert the key into the ignition and remove it (don't turn it...just remove it). 4. Using the MANUAL lock switch on the driver's door, lock and unlock the door 5 times. 5. Close the door. 6. Open the door. 7. Lock and unlock the driver's door 5 times (I'm almost certain you use the MANUAL lock switch again, but if this sequence fails to work, try again with the power switch). 8. Insert the key into the ignition and turn it to the "ON" position. 9. Remove the key. 10.The driver's door will now lock and unlock itself one time. 11.Press and hold the "LOCK" button on the key fob for at least 1 second. 12.Close the driver's door. 13.Open the driver's door. 14.Press and hold the "LOCK" button on the key fob for at least one second. 15.Close the driver's door. 16.Press and hold the "LOCK" button on the key fob. The door will lock. 17.Press and hold the "LOCK" button on the key fob again. The door will unlock. You should be all set. |
