Go Back   Automotive Forums Car Chat > Geo > General Discussion
Old 11-16-2004, 06:58 PM
thegrunt thegrunt is offline
95 tracker wont start
95 tracker wont start . it has been running srtange I can hit the gas and it sounds like it wants to die. almost like it gets to much gas. now it wont start. any help would be great.
Old 11-30-2004, 08:51 AM
hesszoo's Avatar
hesszoo hesszoo is offline
Re: 95 tracker wont start
There is just so much that could be wrong: What do you mean by running a little strange? was it misfiring, loping, have hesitation, fuel odor, as you can see the better information you give the better you will get.
My only recommendation with such a general description would be to check for vacuum leaks (loose or broken vacuum hose in Eng compartment) or change the fuel filter (located under the vehicle toward the rear near the gas tank) when changing the filter make sure the fuel system is not pressurized
Old 04-01-2005, 07:23 AM
Mikeee Mikeee is offline
Try replacing the oxygen sensor..
