Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 11-16-2004, 06:39 PM
my97blackgst my97blackgst is offline
420a cutting out and missing
Hey,
I have a eclipse with a 420a/auto trans in it. It's a 98 btw. In 1st gear no problems, 2nd gear no problems, 3rd gear from 1800rpm-2400rpm cuts and misses, and the same with 4th (OD) I think it's fuel related but not sure. I replaced the fuel filter today (Orignial OEM filter...138,000miles) and that did not cure it. It's like anytime it needs to develop tourqe and needs the extra fuel it cut's/misses....I think I am in the need of a fuel pump...what do you think it is.
Cheers
Ben
P.S I have new plugs, wires (MSD super conductors) K&N air filter. And it's not bad gas.....I already drained/refilled the tank
1997 Mitsubishi Eclipse GS-T, Auto, A few small upgrades
Old 11-16-2004, 08:08 PM
EclipseBabe95 EclipseBabe95 is offline
make sure your plugs are gapped correctly, i had to regap mine to solve a similar problem
BUY MY CAR!!!! www.clarkson.edu/~desjarrf/keldra.htm
very reasonable price....
[email protected]
Potsdam, NY
2001 Yamaha YZF600R
95 Eclipse GS
Old 11-16-2004, 09:57 PM
anarchy1114's Avatar
anarchy1114 anarchy1114 is offline
Send a message via AIM to anarchy1114 Send a message via MSN to anarchy1114 Send a message via Yahoo to anarchy1114
try your coil pack... might solve the prob. i was having similar probs with my eclipse (98 gs, 5 spd) when my alternator started to go out. but with more symptoms. are there any dummy lights (i.e. check engine light, battery light, srs) on ??? that would help us more ....
If it has tits or tires it will give you problems, but atleast you can fix the problems with the tires
2007 Trailblazer - stock
97 GS-T -> lots of mods
98 GS ->total loss, now being parted out
Old 11-17-2004, 01:27 AM
Re: 420a cutting out and missing
Well...I already gapped the pugs to what the factory said. I forget the gap...but I did recheck them. There is no dimming on the lights...the alternator was recently tested and was dead on perfect. Keep the comments coming!!
Cheers,
Ben
