Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 11-16-2004, 06:29 PM
intrepid-fan intrepid-fan is offline
Angry 1997 intrepid radiator --- does it have a drain
Does the radiator on a 1997 intrepid 3.3l have a drain?
I want to replace my antifreeze but cannot find the drain??
HELP!!!!
Old 11-19-2004, 02:44 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 1997 intrepid radiator --- does it have a drain
Check underneath the radiator drivers side, there should like a "T-shaped" wing nut that will allow you to drain the coolant.
Old 11-21-2004, 02:56 PM
Re: Re: 1997 intrepid radiator --- does it have a drain
Well I looked and I cannot really see underneath the radiator. Is it possible that I have to remove the radiator? I do see two rubber bushings that support the radiator, is it inside one of these bushings?
Double checked the side of the radiator next to the lower radiator hose with no success, also checked the front and back at the bottom
I cannot gain access to underneath the radiator unless I lift it up a bit.
Many thanks for your reply but I am still frustrated.......
Old 11-22-2004, 04:48 AM
push comes to shove, if you're really desperate to drain your radiator, pull off the lower radiator hose and that will drain the coolant from your radiator. Did that on my old '85 Mustang; drain cock was frozen on the radiator that I just pulled off the lower hose.
