Go Back   Automotive Forums Car Chat > Honda > Prelude
Old 02-25-2002, 07:46 AM
WhiteIce WhiteIce is offline
Question FRITZ.....PLEASE>>>HELP or any other TECH Savy GURU
Fritz or others,
My 98 Lude has only 28k miles on it and it is making a wierd noise. It only happens on the very first start and that is it. I don't live in a cold region and I take it to all the required check ups. Every morning for the past week or so...when I go to start it...it makes a POP and it does start....it just makes like a METAL POP!!!! Do you have any idea what it could be?
Thanks,
WhiteIce
Old 02-25-2002, 04:55 PM
fritz_269's Avatar
fritz_269 fritz_269 is offline
Nothing immediately jumps to mind.
Does it make the sound no matter if the engine is warm or cold when starting it? e.g. After driving 15+ min, shut her down, wait 5 sec, and start her up again - do you get the noise then?
Is it a 'pop' like a champagne cork, or more of a 'click' like a rimshot?
Have someone else start the car while you listen for it with the hood up - can you locate approximately where the sound is coming from?
Other than your Thermal, what mods do you have?
Are you still under warranty?
Old 02-26-2002, 07:50 AM
Fritz,
It only makes it on the first start....my Thermal is the only Mod that I have done. It will not reduplicate the sound again...until the next day the first start. It sounds like it is coming from the engine bay.......Like a POP!!!
Thanks in advance for any input,
WhiteIce
I am not under warranty.....just ended...
Old 02-26-2002, 02:30 PM
fritz_269's Avatar
Strange. Again, nothing really comes to mind.
As a wild guess, I might say that you have a ever so slightly leaky fuel injector, and you're getting a small intake manifold backfire after it leaks down the residual pressure in the fuel line overnight.
You might try running a bottle of fuel system cleaner like Techron. As I said, it's a wild guess - but it couldn't hurt to try.
Good luck.
Any idea if any other struts fit the 96 MX3 tookalook MX-3 0 07-12-2009 07:31 PM
Weird brake light problem, ANY CHEVY TECHS AROUND PLEASE HELP sniper4x4 C/K 7 07-26-2004 11:22 PM
Any 325xi website suggestions? and any other info. world_worker 5 Series 0 01-26-2004 09:05 PM
Any Honda Techs In The House? thebobs Engineering/ Technical 8 09-11-2002 06:10 PM
