Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 11-16-2004, 03:53 PM
ebra30291 ebra30291 is offline
Bucking Isuzu Rodeo
I have a 2002 Isuzu Rodeo with 2.2 Liter Engine, 5 Speed Manual Transmission. About five days ago, the car started bucking and sputtering like it not getting any gas. I changed plugs, wires and fuel filter. Now the car won't go past 60 mph. I got a check engine light and had it diagnosed as the camshaft position sensor. Does this sound right or can it be something else. The light keeps going on and off.
Old 11-16-2004, 06:10 PM
SOLSTER SOLSTER is offline
I have no idea if this will help, but it caught my attention as it's titled "THE BUCKING ISUZU RODEO"
http://www.misterfixit.com/izuzzu.htm
SOLSTER
1999 Isuzu Rodeo S 3.2L, 4x4, Auto, Great Truck!
2007 Pontiac Solstice GXP, Aggressive Red
Old 11-16-2004, 07:45 PM
surferfletch surferfletch is offline
Re: Bucking Isuzu Rodeo
Has your timing belt been replaced as recommended?
Old 11-17-2004, 05:27 AM
rodeo02 rodeo02 is offline
Check this thread: http://forum.planetisuzoo.com/viewtopic.php?t=2501
G/luck
Joel
2016 Subaru Forester 2.5i base CVT
2016 Nissan Quest SV
Old 11-22-2004, 07:37 AM
That's the thread I started on that forum. I still don't know what's wrong with the car.
Old 11-22-2004, 09:39 AM
Does the camshaft position sensor continue to throw a code? If so, that's where the problem lies. I'm not positive where it's located, but it most likely picks up it's signal from a cam sprocket, which would be located behind the (plastic) timing belt cover. This sensor is what sets your ignition timing and/or fuel injector timing. If it's not sending a clean signal, your truck will run like poop, or not run at all.
G/luck
Joel
Old 11-22-2004, 09:46 AM
Thanks,I am ordering the sensor today. I really appreciate the help.
Old 11-22-2004, 05:30 PM
Are you sure it's not a perfectly good sensor telling you the timing belt/tensioner is faulty? That's the purpose of a camshaft position sensor.
Old 11-22-2004, 08:01 PM
Re: Re: Bucking Isuzu Rodeo
This engine wont run with the valve timing off. The pistons will hit the intake valves if the timing is even off a hair (1998+ 2.2L).
Joel
Old 11-22-2004, 09:00 PM
Wow. I didn't realize that. That's very different from my 2.0L VW, engine and other engines I've seen, which will run rough with the timing off. Many of those engines must crack pistons and bend valves.
