Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 11-16-2004, 02:19 PM
neight neight is offline
Unhappy Fuel Gage Problem
Hello, Everyone.
I am a new person to the board and not very good mechanically speaking, so take it easy on me
Okay, here is my problem:
I have a 97 Pontiac Bonneville, everything seems to be fine on it with exception to my fuel gage. It will not register 99% of the time. Every once in a while the needle will show some indication that it works, but goes right back to full. I have to guessimate my fuel consumption which is nerve racking. I have ran out of fuel a few times and I am tired of it.
If any of you have encountered this, please let me know what I should do or look for. Thanks.
Nate
Old 11-17-2004, 05:14 PM
markwb's Avatar
markwb markwb is offline
Re: Fuel Gage Problem
Nate, This fuel gage failure is a common problem on the GM platforms. The only real solution is to replace the fuel sender unit, as this is more than likely the problem. The resistor pack internal to the fuel level assembly in the tank fails, leaving you with the symptoms that you've described.
Mark
2003 Pontiac Bonneville SSEi, 1999 Ford Escort SE, 5 Speed
IBEW Local 261 Groton, CT
Old 11-17-2004, 06:07 PM
Hmmm, okay. Thanks for the information. I assume that this would be quite pricey to replace. I am correct?
