engine check light reset
a simple question -- where is the check engine reset switch located for my 1998 escort?
I'm not aware there is one...
You can clear codes by... 1. OBD-II scan tool...Autozone used to clear the codes if you asked but now there appears to be a rule they can't...maybe got sued when an engine blew because owner didn't fix a problem after autozone told owner the problem. 2. Remove negative lead from battery for a few minutes....erases the computer memory. You lose your radio presets, tho. Now, if you haven't fixed the problem that caused the check engine code, it will be back. |
