Old 11-16-2004, 09:22 AM
george536's Avatar
george536 george536 is offline
annoying buzz coming from somewhere. JAKE!!!
Ok i installed my radio and there is a loud buzz coming from somewhere. Everytime i step on the gas it gets higher and i let go and it gets low again. Anybody know what this is?it sounds like it comes from the dash. when the car isnt on it doesnt sound like that. HELP!!
-1997 Eclipse Spyder GST |Stock|
-1990 Eclipse GSX
|ACL Main & Rod Race Bearings|Balance Shafts Removed|ARP Head Studs|Cometic HG|FP 20g TDO6H|EPROM Chipped (stutter box 5k, fuel comp.)|PTE 680cc inj.|Walbro 255 HP Fuel Pump|Autoteq FPR|SAFC 2|FMIC|2g MAF|Dejon Tool Hard Pipe|Greddy Type S|MBC at 17PSI|Ported 2g Exhaust Manifold|02 Housing w/ Tial 38mm WG|Full 3inch Exhaust w/ Y-pipe Cutout|Fidanza Flywheel|ACT 2100|4 Bolt LSD Rear|Poly Mounts|KYB AGX Suspension|Roll Bar|
Old 11-16-2004, 10:14 AM
thecackster's Avatar
thecackster thecackster is offline
Send a message via MSN to thecackster
I know what your talking about, my friends crysler van used to do that with the back right speaker, I will ask them how they fixed it I want to say they just unhooked the speaker, and I know thats really not an option for you but i think that it may have a bad connection and might be grounding out somewhere??? Hope this helps, probably didn't.
97' Chevy Silverado
K/1500 Z71
350 Vortec
Flickr My Website
Old 11-16-2004, 10:16 AM
real_madridcf's Avatar
real_madridcf real_madridcf is offline
Send a message via AIM to real_madridcf Send a message via MSN to real_madridcf Send a message via Yahoo to real_madridcf
Did this happen exactly after you installed the radio, or did you make any other changes with that? Try to narrow what it could be down, so you dont have to pull everything apart.
95 Eclipse GS: OBX Full Exhaust System, OBX Headers, OBX Short shifter, OBX Spark Plugs & Wires, 17' MSR Rims w/ Wanli tires
96 Eclipse GS-T : K&N Filter w/ Hardpipe, UICP & LICP, Greddy Type S bov, Greddy Boost Gauge
Hala Madrid!
Old 11-16-2004, 01:03 PM
EclipseRST's Avatar
EclipseRST EclipseRST is offline
Banned
Send a message via AIM to EclipseRST Send a message via MSN to EclipseRST Send a message via Yahoo to EclipseRST
Re: annoying buzz coming from somewhere. JAKE!!!
use a better ground location... either that or run a wire strait from the negative on the battery to the ground wire on the deck.
are you using an amp? if so make sure that is grounded good and if that still doesnt help then you need a new set of RCA wires. (this is only if you are using an amp)
Old 11-16-2004, 01:20 PM
scottsee scottsee is offline
Send a message via AIM to scottsee
yup. if you really want to get rid of that hiss you can buy my audio controle 4.1 crossover. like they said, thats a grounding problem. if you have an amp installed, make sure the remote & constent power wires are no where near the RCA's and Speaker wires. it best to seperate them as much as possable, its also a great idea to stick your Power/remote together and brade them, or put them in your cordless dill and wind them together, same with your speaker wires, and rca. that helps THD, not significantly, but a little. if you still have the problem after what jake and i said, let me know, i'll help you track it down
DSM geek
Old 11-16-2004, 05:51 PM
george536's Avatar
So i need a better grounding? i dont have an amp on. so juss run the ground from the deck from the negative on the battery?
-1990 Eclipse GSX
Old 11-16-2004, 06:16 PM
yea, start with the ground wire, if you can drill a hole into the firewall and and use a screw & o connecter to ground it out, you wont have to run a wire all the way to your battery. if that dosn't get rid of the problem goto radio shak and get a noise suspressor, (little resister box 1 power wire W/ 2 grounds) it put it inline with your deck wires to reduce signal noise. use the other ground wire to stick on your firewall. Most decks now a days come with internal signal processors, or other noise filters. is that a new deck? my cars had that problem. it was my mbquart 5 1/4 componets. the 4 gauge power wire was ran through the passenger side door molding, along with my amp wires causing interfearence with my right / fronts becasue they were running together back to the amp. i seperated the speaker wires and power wires, while it helped, it didnt get rid of the problem so i had to get a signal processor to get rid of it all.
sorry to hear about the noise polution
DSM geek
Old 11-17-2004, 01:11 AM
george536's Avatar
Ok thanks ill try this tomorrow.
Hey jake i always wondered what the people installing radios have in there cars? do you have like tvs popping out the floor or something. Cuz you guys put soo much cool stuff in cars you just mite get stuff cheaper or somethin.
-1990 Eclipse GSX
Old 11-17-2004, 01:16 AM
george536's Avatar
HAHAHAHA now that i remeber. I was giving my friend a ride that drives a civic. and hes kinda clueless about dsms. he just knows they have turbos. And all of sudden he heard my buzzing noise getting higher everytime i steped on the gas. So he asks whats that? so i get stuck on what to say "oh thats my turbo spooling up" and hes all like "wow that sounds cool" I busted out laughing in my head how clueless he was . the sound was horrible, but once i said it was a turbo he was all over how cool it sounds. I had the greatest laugh of my life when he got out the car.
-1990 Eclipse GSX
Old 11-17-2004, 04:09 PM
george536's Avatar
grounded it to the negative on the battery and its still not gone. i had a stereo in there that did it, and i thought it was the stereo and i replaced it and its still doing it. ill go to radio and get what scottsee said to get. any other suggestions?
-1990 Eclipse GSX
Old 11-17-2004, 04:24 PM
try that, then post.
DSM geek
Old 11-17-2004, 04:56 PM
gthompson97's Avatar
gthompson97 gthompson97 is offline
Send a message via AIM to gthompson97 Send a message via MSN to gthompson97
i had that same exact problem. what happened was when i had my amp hooked up, i used the radio power wire because i didn't know which one was the remote cause it's japanese wiring. then i found a wiring diagram and hooked it up to the regular remote from the car an it quit. the buzzing is coming from your speakers and the speakers are picking up an interference from somewhere. if that doesn't work, make sure all the connections on your radio are connected correctly and that they aren't grounding out or something. let me know how it turns out.
95 Talon TSI AWD
97 Eclipse GST
Old 11-17-2004, 05:49 PM
george536's Avatar
ThankS!!!! scottsee i went to go buy the noise thing from radio shack and that completely solved my problem. Thanks you saved me from having to go to an audio place to see whats the problem
-1990 Eclipse GSX
Old 11-17-2004, 08:19 PM
welcome. anytime
DSM geek
