Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 11-16-2004, 07:07 AM
carderallen carderallen is offline
Question Mass Air Flow Sensor
My 2001 sable had the check engine light come on. I took it to auto zone where they said that the "code" was a mass air flow sensor and it had something to do with the air filter. Could someone explain what this code means and is it something that I could fix myself. Less than a year ago I had to replace the exhaust sensor...does this car typically have a problem with it's sensors?
Any help would be greatly appreciated.
Old 11-24-2004, 08:06 PM
rivguy rivguy is offline
Send a message via Yahoo to rivguy
Re: Mass Air Flow Sensor
depending on what the code number was depends on the problem - the MAF measures the amount of air entering the engine to determine the proper amount of fuel to give the engine - the maf is easy to change - it mounts to the air cleaner cover - but in most cases you can remove the 2 screws from the sensor and use carb cleaner with an old tooth brush and clean the old one
-=-=-DANE-=-=-
