Old 11-16-2004, 12:29 AM
seanmag seanmag is offline
alternative for remote wire
I recently bought a new car, and am moving my sterio over. I can not however remove the factory deck to hook up the remote power wire to my amp. I have the tools to remove the factory sterio, it just won't budge. Given this, is there anything else that i can hook the remote wire up to. I thought about the cig lighter, but most of the wires are taped up solid underneath the dashboard and hard to access...
Any ideas?
Sean
Old 11-16-2004, 12:56 AM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: alternative for remote wire
you'll have to find something that's switched with the ignition....cig lighter, something in the fuse box, etc
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 11-16-2004, 09:25 AM
TFFantasy44 TFFantasy44 is offline
Or you could find a constant power source, and stick a switch on it. But you'd hafta turn it on and off when you get in and leave the car.
1996 Cavalier 2.2
[size=-1]
Audio Set-up
--Currently have--
NINe.1 Amp
eD 15A.22 Sub
Alpine 9855 Headunit
Old 11-16-2004, 01:48 PM
hotwheelsgt's Avatar
hotwheelsgt hotwheelsgt is offline
Send a message via MSN to hotwheelsgt Send a message via Yahoo to hotwheelsgt
in my car the cig lighter is constant, are you sure that it is swithced?
Old 11-18-2004, 12:10 PM
The cigarette lighter is a good option, in my car it turns off when the car turns off. The problem though is access to the wires. In the car, all the wires are taped together with electrical wire and them fascened to the underside of the dashboard. they are just very secure, and hard to get to. I'd rather not cut down a whole group of wires, and i tried to follow the wires to find a spot where they wer more accessable, but had no luck with that...
Old 11-21-2004, 10:05 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
My freind once had his deck switched wire (red) not only hooked to the accessory to his ignition, but also to his parking lights, so when he'd turn the parking lights on, the deck would turn on, not a bad idea. just a thought...
