Old 11-16-2004, 12:05 AM
SsHaDyGt SsHaDyGt is offline
what grade gas to use??
Im running a 3.4 inch pulley and tr66 plugs do i have to use the 93-94 octane the price is killin me
1998 silver gtp, GM performance Handling kit ,cold air intake, KYB struts ,HD supercharger coupler ,Gatorback belts ,U bend delete ,NGK TR6 plugs ,DHP PCM, Electric exhaust cutout - SOLD
98 White GTP, N* TB, 3.0 MPS pulley, SLP headers, 1.9 Rockers, 105# springs, ZZP PCM, Flowmasters, GM performance Handling kit, FWI, GMPP springs, U bend delete, SSIC, Ported LIM, Autolite plugs, ported SC, 12" brake upgrade with slotted cross-drilled rotors,
Old 11-16-2004, 12:38 AM
94sportsedan 94sportsedan is offline
Price you pay for performance
Old 11-16-2004, 12:43 AM
93cobra 93cobra is offline
Send a message via AIM to 93cobra
Re: what grade gas to use??
You should use premium grade with the supercharged 3.8. I believe it's in the owners manual too. If you use lower octane you will eventually cause engine damage. You could use the lower octane on the non SC 3.8s.
Old 11-16-2004, 05:45 AM
GTP Dad GTP Dad is offline
Pontiac Guy
You need the highest octane you can get on the supercharged 3.8. 93 or 94 is good. If you use 87 or 89 you will experience severe detonation on hard acceleration and end up with a destroyed engine. Anytime you compress air in the combustion chamber you need the higher octane to decrease the possibility of pre-ignition (detonation) otherwise the noise you hear may be parts breaking.
