Old 11-15-2004, 11:51 PM
nismo#1 nismo#1 is offline
HELP!95 sabre 3.8 big prob
Ok here is the prob,it is a 95 lesabre and it has been stalling and bucking when i drive,i changed the fuel fillter and that worked for about 30 miles or so then it started acting up again.What is weired is the car runs fine untill the check engine light comes on then its startes jerking while im driving. When im at a stoplight it idles ruff and also stalls sometimes and surges and pulls.So i dont know anyone have a idea? also how can i pull the codes and where?
Old 11-16-2004, 12:48 AM
lakerfan1784 lakerfan1784 is offline
Send a message via AIM to lakerfan1784 Send a message via Yahoo to lakerfan1784
Re: HELP!95 sabre 3.8 big prob
your EGR valve is probably stuck, it should close when the car is warmed up, its probably that, because its throwing a code. It is probably a good idea to change it anyway.
Do sober what you say you will do when you're drunk. that will teach you to keep your mouth shut.
Old 11-16-2004, 01:29 PM
ok ill try that
Old 11-16-2004, 08:15 PM
buickmastermind's Avatar
buickmastermind buickmastermind is offline
Goto autozone and have them check the codes- they'll do it for free. It might not be the EGR. More likely the cam sensor, but get it checked before you start fixing it.
1986 LeSabre Limited L67 sleeper
Fully ported & polished, shift kit, CAI, F41 polyurethane suspension, headers & 3" exhuast,
Old 11-17-2004, 12:30 AM
basamjy basamjy is offline
Try "dry gas"
Yes i would go to AutoZone to get a free "computer code readout" first. sometimes they have a mean person who will do it but refuse either to explain what error code mean and/or refuse to erase the error code from your car computer ! just go another time when the mean guy is not there.
something like your car problem happened to me twice before...first time i used "dry gas" which is a $2.99 bottle to mix with fuel to clean fuel system from any water. it worked great !
second time last week when a "mechanic" fixed a hose but broke the "MAP" sensor...and the car was running rough and funny on idle like your car is doing. today i got my new sensor and installed it.
Old 11-17-2004, 06:49 PM
avatar307's Avatar
avatar307 avatar307 is offline
I'd be willing to bet AutoZone won't be able to pull the codes from your LeSabre. My 1995 LeSabre has the 16-pin OBD-II style plug, but has the wrong pinout to be OBD-II.
Current theory, for anyone concerned, is that the computer actualy still uses ALDL 8192 baud serial protocols over the modified connector. In the process of ordering circuit boards and IC chips to build an interface to test this.
"Sleeping is the only thing keeping me from killing all the stupid people on this planet."
"Of one that loved not wisely but too well;" (Othello, Act 5, Scene 2, Line 344)
Old 11-19-2004, 07:35 PM
piewagn's Avatar
piewagn piewagn is offline
Probably plug wires & plugs. That year had problems with carbon traking down the plugs. this concern get worse the hotter the engine gets. Pull the plugs out & check the porcelain portion of the plug. The carbon track look like tiny "lightning bolts" down the side of the plug. You can't replace just the plugs, because, the plug boot is contaminated also.
