Old 11-15-2004, 11:10 PM
youngvr4's Avatar
youngvr4 youngvr4 is offline
STREET RACING GURU
If It Aint One Thing, Its Another, And Another!
well i just got my brakes fixed.
but my battery needs to be replaced $69.99
i have an oil leak(most likely my turbo's) $1000.00
and my damn struts are on there last breath $1800.00
why me?
well i'm not punking out, i'm geting it all fixed somehow, cause i aint getting rid of my best friend.
i need all you guys help to get everything i need cheaper(exept the battery) the best i can do is get a personal loan for $2000.00 and just save up the rest.
i need help!
Old 11-15-2004, 11:39 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
Re: If It Aint One Thing, Its Another, And Another!
Wow how does a leak cost $1000? You could try getting some lightly used struts off of 3SI from a part out or 3SX sells them for $359.95, and I don't think it'll cost $1450 to install the strusts. Are those estimates from a dealer or what?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-15-2004, 11:59 PM
youngvr4's Avatar
STREET RACING GURU
from some place called american car care.
ok struts are $359 you said?
so what about some turbo's
Old 11-16-2004, 12:40 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Struts, I would go 3sx, or get some coil overs while your swapping them.
If your turbos are leaking oil it will be into the intake and you would never see it, so if you are getting oil on the ground it is not your turbos going bad.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-16-2004, 04:15 AM
BB1970's Avatar
BB1970 BB1970 is offline
i cant wait for my 9b's to blow again, beleive me young vr4 its worth thinking about upgrading those babies as a set of 13g's or 15g's wont be much more and you can always regulate the boost with your controller until you can afford the extra ancilleries to let those babies breath. i made a big mistake by rebuilding mine, although i did it myself and it didn't cost that much im severely regretting spending the cash on them rather than putting it to some better turbos.
1993 Mitsubishi GTO Twin Turbo (RHD) NOW SOLD!!!
9b turbos with manual boost valve mod set @14psi
turbo xs type h-rfl blow off valve
blitz dome filter
sachs clutch
completely de-catted
fuel pump voltage rewire mod
ebc redstuff front brake pads
greddy fully automatic turbo timer
now drives a sensible family sedan. A 340hp 1997 mitsubishi evolution IV
Old 11-16-2004, 05:15 AM
Thourun's Avatar
Yea I think you should get a second opinion on all of that, sounds like that shop was trying to gouge you. If it was your turbos leaking then as stated it would go into your intake and you'd just burn it up (while guming up everything in between), you could just get/make a catch tank to solve that real simply. Hopefully the oil is nothing serious though, good luck on geting it all fixed up.
1995 3000GT VR-4
Old 11-16-2004, 05:33 AM
GritMaster GritMaster is offline
If you want some help installing contact me :P
RIP Andy "Hypsi87" Filson... We'll miss ya mate
Originally Posted by nissanstreetz
For about 700 dollars you can have about 80 horespower at the wheels and about 70 torque.
Old 11-16-2004, 03:33 PM
Igovert500's Avatar
blue + red light magnet
Well you said not the battery, but I got mine at autozone for $42...
that aside, I think everyone else has good suggestions..aftermarket upgrades may be cheaper/wiser
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-16-2004, 03:49 PM
uncutnick3kgt uncutnick3kgt is offline
Send a message via AIM to uncutnick3kgt
well first i would suggest if u have to get new struts and such u should check out tein....because if u have to get new ones u might as well just go all out and get nice ones that will help your rides performance.....also if u do decide to get strust from tein they come with the instructions on how to install them...thats just my 2 cents...
Old 11-16-2004, 06:19 PM
youngvr4's Avatar
STREET RACING GURU
thanks you guy's!
Old 11-17-2004, 10:58 PM
Hotshot8792 Hotshot8792 is offline
Re: Re: If It Aint One Thing, Its Another, And Another!
i feel the pain, these cars never like to stay in one piece
Daily Driver: 2004 Jeep Grand Cherokee Special Edition
1994 Mitsubishi 3000GT SL-TT Automatic - Black
3.05 L Arias Forged Pistons, Pauter Forged Rods, DR Stage 3 heads, 3SX TD05 kit w/ E16G's, CX Racing FMIC, 550cc injectors, Walbro 255lph pump, + supporting mods
1994 Mitsubishi 3000GT VR-4 - Black
Intake & Boost Controller so far
2006 Sea-Doo RXP Supercharged, Updraded SC, IC + supporting mods
Old 11-17-2004, 11:08 PM
Getsum3kgtsl Getsum3kgtsl is offline
I DO understand, I took my car to the shop to get an alignment and found out it was the control arm, I got the control arm after a week, took it back, found out the K frame was screwed, left it at the shop for 2 weeks til it got in, and got $900 lifted out of my pocket. Let's get a beer and talk about it, lol
Old 11-17-2004, 11:11 PM
youngvr4's Avatar
STREET RACING GURU
i'm just thinking that either i can spend 2-3 grand on some stronger turbs or save that money to rebuild the engine if the case comes.
Old 11-18-2004, 08:04 AM
YogsVR4's Avatar
YogsVR4 YogsVR4 is offline
Funding the welfare state
Send a message via AIM to YogsVR4
Its never a bad idea to save up money. However, saving specifically for something that could never occur is questionable. If you intend to spend the money on the car, getting the better turbos would be the way to go.
Resistance Is Futile (If < 1ohm)
