Old 11-15-2004, 08:06 PM
bBoYLXIX bBoYLXIX is offline
Send a message via AIM to bBoYLXIX
amp went out (amp prt. light on)
ok this is probably a dumb question. but how do i get the amp to work after the amp protection light comes on? my amp went out during a long drive and i check and sure enough, the amp protection light was on. so i figured it would go off and the amp would start working again after it kooled down. well it didnt. a few hours later its doing the same thing. and i cant get it to work again. ive looked in the manuals it came with but it doesnt say anything about it. the amp is an audiobahn A4401T with the 2 10" 600w box. please help if u can. thanks
Old 11-15-2004, 08:09 PM
sr20de4evr's Avatar
sr20de4evr sr20de4evr is offline
Re: amp went out (amp prt. light on)
how long was it working before it stopped?
'01 Black Sentra SE
Weapon-R intake, HS header, HKS catback, ES motor mounts, B&M short shifter, Tein coilovers
Alpine 9835, Adire Koda 6.1, Adire Brahma 15, Arc 2100cxl, Linear Power 2.2hv, Cadence ZRS-8
'05 Silver WRX STi
Injen SES Downpipe, HKS Carbon-Ti catback, Cobb Stage 2 Tune, TiC Super Shifter, TiC Klunk Killer, Tein springs, Nitto NT555R Drag Radials
Old 11-15-2004, 08:27 PM
about 3 months with no problems.
Old 11-15-2004, 09:01 PM
sr20de4evr's Avatar
Hopefully your amp didn't take a crap, but it sounds like it did. See if you can open it up and look for any black or brown burn marks around the transistors. Also is there any chance you have a multimeter?
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-15-2004, 09:08 PM
i do. ive done some basic circuitry b4 so i kinda know my way around electronics. im no expert about it, but i might be able to fix it if im told what i need to do. what am i gonna have to do if i see the burn marks around the transistors? could u try to lay out what i might encounter and how to fix it? if u could that would be awsome. thanx.
Old 11-15-2004, 10:14 PM
sr20de4evr's Avatar
Well if that's the problem, you'll need to find the model number for the transistor(s), order a replacement, and solder a replacement in. The problem is many times more stuff will blow that you don't know of, and without an intimate knowledge of how amplifiers work I doubt you (or I) could find all the problems. But, if you open it up and find a blown transistor, that's an immediate indication that the amp is the problem and it's not something in the install. The multimeter is to measure the resistance of your subs, to make sure you didn't accidently blow one. If you did, there would be a short, and your amp would go into protection to protect itself from being damaged.
Another way to test that is to remove the subs from the amp (just disconnect the speaker wire) and then power up the amp and see if it still goes into protection.
You should also measure the voltage at the amp, the power input and the remote input, to make sure both of those are up to par.
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-15-2004, 10:51 PM
Haibane's Avatar
Haibane Haibane is offline
Send a message via AIM to Haibane
Why are there constantly being ads added. Think i am going to leave this forum eventually with all this crap.
www.cloudcity.deviantart.com
Old 11-15-2004, 11:03 PM
sr20de4evr's Avatar
yeah this is getting horrible
'01 Black Sentra SE
'05 Silver WRX STi
Old 11-15-2004, 11:36 PM
damn it. audioahn is crap. that lasted 3 months! anyone know how much a repair on an amplifier would be?
Old 11-15-2004, 11:54 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
yeah, depends on who you go to, it usually costs me about 20 bux to repair them, give or take 10 bux. Best buy will usually charge 90 or more. I'd find someone who knows what they are doing, and have them do it, a friend maybe.
Old 11-16-2004, 10:20 AM
TFFantasy44 TFFantasy44 is offline
He's seen the light! My audiobahn amp lasted 3 hours before it took a shit and I did nothing wrong, with gain at about a quarter way up
1996 Cavalier 2.2
[size=-1]
Audio Set-up
--Currently have--
NINe.1 Amp
eD 15A.22 Sub
Alpine 9855 Headunit
Old 11-16-2004, 03:24 PM
Mannyb18b's Avatar
Mannyb18b Mannyb18b is offline
Send a message via AIM to Mannyb18b Send a message via MSN to Mannyb18b
Ya, hai might rem. when i was a newb to car audio and was asking if the 2 audiobahn 12's in bandpass box and power acoustik amp was a good setup. He sug. E.designs, but being the dumb newb i was i went with the setup. I have to say that I am pretty happy with it so far (except for replacing agu fuse 3 times already) but when they start shipping I will have a E.D 16OV.2 and Nine.1 in my trunk ported.
Old 11-16-2004, 09:49 PM
well i found the reciept, ill see how far that gets me for the one year warranty. probably not far i suppose. even if i do get it exchanged or fixed i think im gonna sell my whole setup for some kickers or something. anything but audiobahn. anyone have some good suggestions?
