Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-15-2004, 06:51 PM
nismo300zx nismo300zx is offline
help me please..... 1990 300zx
have a 1990 nissan 300zx, today while i was going to school, i was drifting in the Z
but then suddenly i lost alot of power, and a loud metal noise came on.....i thought i crap, i dont have oil and my bearings are gone, but i check the oil and it was fine, i put some more and right now its not burning any oil....
but the problem still there, i get the metal noise, like "TEKE TEKE TEKE " and the car doesnt have any power....i mean it runs, but really slow, and if u press all the gas, the sound is louder..
what could it be?? help me out....tnx by the way....
Old 11-15-2004, 07:07 PM
rendertrust's Avatar
rendertrust rendertrust is offline
Re: help me please..... 1990 300zx
sounds to me like the torque converter but then of course i dont know where its connected or what its even connected to, i dont know anything about cars forget my post
Old 11-15-2004, 07:24 PM
neogenesis neogenesis is offline
5 Speed or Auto?
Old 11-15-2004, 07:36 PM
Re: Re: help me please..... 1990 300zx
Originally Posted by neogenesis
5 Speed or Auto?
5 speed
Old 11-15-2004, 08:17 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
is it coming from your engine or the underneath you. you could be grinding a gear causing a grinding of metal sound. this will cause loss in power because the transmission isnt fully engaging into that gear. or if its coming from the engine, sounds to me like a piston got loose and bent a valve or something of that nature. dont over fill the oil....
also, if its coming from the back of the car, could be that your carrier bearing in your drive shaft went out. differential??? give a little more detail...
ZedEx Crew Member #4
Old 11-15-2004, 08:19 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
DO NOT overfill or underfill the oil. if the sound is coming from the engine, DO NOT drive it anymore, don't even start it. if it is making a noise like you say it is, there is something wrong internally, and the engine running will make it even worst. and not to be the bearer of bad news, but you might need to do a rebuild.
-Jared
ZedEx Crew Member #2
Old 11-15-2004, 08:34 PM
its coming from the left head....the sound is from the engine...the left part is the one who does the noise
Old 11-15-2004, 08:37 PM
Z Cars Fanatic
its probably internal like i said before. if you didnt loose power then it could have been a few other things that wouldnt have been a big deal. you have a TT or n/a???
Old 11-15-2004, 08:43 PM
i have an na.....
so what you recomend me to do??
Old 11-15-2004, 08:48 PM
Z Cars Fanatic
tow it to a trusted local shop...see what they say and go from there. if they say you need a new engine or yours rebuilt, do some research before you have them go ahead and start it. also, come back here and ask us what we think. im sure someone here will be able to tell you if that sounds like a decnt price or they are trying to rip you off.
just so you know, if you need your motor rebuilt. i think the cheapest and best route to go would be to find someone who will pull the engine for you for free or cheap. family, friends, or neighbors. then take the block engine to a local machine shop. they will rebuild it fresh so there is 0 miles on it for very cheap.
Old 11-15-2004, 08:51 PM
tow it to a trusted local shop...see what they say and go from there. if they say you need a new engine, do some research before you have them go ahead and start it. also, come back here and ask us what we think. im sure someone here will be able to tell you if that sounds like a decnt price or they are trying to rip you off.
do u think with 2 grand ill be able to buy a used engine and them to install it to my car??
or it could be much more than that?
or how about if we just fix my engine, it would be cheaper or expensier?
Old 11-15-2004, 08:56 PM
oh no, we have everything in my garage to pull out engines and everything.....thats not a problem
how much you think a rebuild will cost me?
Z Cars Fanatic
2 grand should get you a used n/a engine installed, probably cheaper. it might be cheaper to fix the engine you have or it might not. depending on how much is damaged once they break it open. now would be a good time for a TT swap if you wanted.
BTW: my opinion would be to buy yourself a used engine, have someone drop it in for you. then you have an extra engine, when you get some money together, take it to a machine shop and have them rebuild it with performance parts and lower the compression, then slap 2 turbos on it. and then when your ready, you got yourself a new POWERFUL engine.
Old 11-15-2004, 08:58 PM
Z Cars Fanatic
i had a local machine shop quote me at ~$500 to hone the block, check the crank, and rebuild the motor with the stock pieces.
Old 11-15-2004, 09:00 PM
hey do u have msn? i really want to talk to you.....i have alot of questions....mine is [email protected]....pliz add me, or i add you
or yahoo messenger, mine is [email protected]
