Old 11-15-2004, 04:14 PM
00BlackGTP 00BlackGTP is offline
Angry It stripped! Now what do i do?!?!?!
I went to change my supercharger oil today and I used a 3/16" allen like the owners manual said and now the hole is round inside!
What do i do now?
Should I try to bang a 7/32" into the round hole, and hope that works or is there a chance I break the housing trying that.
And if that doesnt work then what?
You think you can just do a simple job real quick then something like this always happens.
Sleeper? No, it's not hiding anything. Look at it. It's FAST. You know it.
Old 11-15-2004, 04:31 PM
ericvrose ericvrose is offline
Oh that sucks. I know what you mean. Should be simple no problem and then look what happens. Is there any way you can get a dremmel cut off wheel on it and slice a notch for a heafty screw driver to fit into. I cant remember what it looks like to know if this is a logical thing to try.
Old 11-15-2004, 07:06 PM
Ripn12s's Avatar
Ripn12s Ripn12s is offline
Send a message via AIM to Ripn12s
Re: It stripped! Now what do i do?!?!?!
an ez out would work or maybe try a metric allen
Old 11-15-2004, 08:29 PM
kustomkid54's Avatar
kustomkid54 kustomkid54 is offline
Ripn,
Don't think you should use an EZ out. The metal will end up inside the supercharger. The metric allen may work if you can get a bite on it.
I kind of like "roses" way. If you can cut a notch into it, you could get a large screw driver on it.
Old 11-15-2004, 09:00 PM
thanks guys dreml sounds good but...damn I dont have access to one.
Gonna have to try metric allen first then buy a new plug.
Am I the ony person who has had this problem?
Does GM use loc-tite or something on it?
Old 11-15-2004, 09:01 PM
serves me right for thinking i could just do it at work....
Old 11-15-2004, 10:22 PM
Ripn12s's Avatar
EzOut would be the same idea of a metric allen, just better. Find an ezout that is alittle bigger then the hole in the screw and lightly tap it into the hole, then take a wrench and loosen.
Old 11-15-2004, 10:48 PM
dwalmop dwalmop is offline
You could also try a similar sized torx. It would bite pretty hard if you could wedge/bang it in there
Old 11-16-2004, 12:54 AM
93cobra 93cobra is offline
Send a message via AIM to 93cobra
Re: Re: It stripped! Now what do i do?!?!?!
I agree your best bet is the ez out. Don't use a cheap one. It may snap like a pretzle and then you have a bigger problem. Take your time. You shouldn't get any shavings in the SC unless you drill thru the plug.. Good luck!
Old 11-16-2004, 07:20 AM
How sensitive is the S/C housing? I dont want to crack it tapping something in.
Its made of aluminum right?
Old 11-16-2004, 07:39 AM
Tapping on a new tap shouldn't hurt it. When I had my plug out it looked to be about 1/2 in. deep there. Where you the last one to have the plug out? I believe only a few inch pounds of pressure are necessary to secure that plug.
Old 11-16-2004, 07:48 AM
I just bought the car a month ago and wanted to change the oil, i guess the person befor me used a fxxking impact gun to reinstall it.
Old 11-16-2004, 07:53 AM
Could Be.They're out there. But really you should be able to finess it out . Just take it slow.
Lots of luck!
Old 11-16-2004, 09:03 AM
thanks guys ill be attempting it this aft.
Old 11-16-2004, 11:56 AM
Ok done...
My plug is now a 5mm allen lol
I hammered it in and it came out. (there was f'n loc-tite on it, some people are just dumb i guess)
No problems after it came out.
I used the spray bottle w/some vacuum hose technique.
Worked really good.
Took two full bottles to fill it back up so i guess that means I got almost all of the old oil out.
Thanks for the help guys.
