Old 11-15-2004, 03:33 PM
spidey17 spidey17 is offline
Question Headlight sensor
My headlights go up on my 1995 Firebird and stay up. They will not go down during the day like they used to.
I believe that there is a sensor for them on the dash, but can't seem to get to it.
Does anybody know how to do this?
Old 11-15-2004, 03:37 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: Headlight sensor
Does the motor make a sound when you turn off the lights?.
I know of people with this problem but its usually from ground down gears, Also have you tried manual putting them down. If you don't here a sound when you turn off the lights most likely its a problem with the relay.
John
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 11-15-2004, 03:46 PM
I don't believe that it's a problem with the motor because the headlights go up and down when you turn the vehicle off and on. The motors seem to work fine. It's as if no light is getting to the headlight sensor to make them go down.
Old 11-15-2004, 08:00 PM
FormulaLT1's Avatar
Fight the powwa!!!
I'm sorry I have no idea in the world what your talking about because the headlights are no light activated on your year, As far as I know but I was questioning if it made a sound not if it was working but one more question, Do you have keyless entry? .
Old 11-16-2004, 03:21 PM
Re: Re: Headlight sensor
Yes, I do have keyless entry. My headlights are also light activated.
Old 11-18-2004, 11:26 AM
cndctrdj cndctrdj is offline
Send a message via AIM to cndctrdj
how did you get light activated headlights?
95 TA - fast
92 240 - fun
96 prelude si - lots o fun
94 cr500r - rediculously fast and fun
Old 11-19-2004, 02:03 AM
chickenkicker's Avatar
chickenkicker chickenkicker is offline
Are you from Canada because the Canadian f-bodies had a light sensor on the top of the dash that would turn the headlights on automatically when it got dark. I'm not sure where exactly the sensor is at but I think it's in the defroster vent on the dash, if so it may have come dislodged and fell into the vent where it's dark.
Black 97 Trans Am M6 - TB Bypass, !CAGS, Manual Fan Switch, 1LE Elbow, K&N FIPK, SLP Loudmouth Exhaust, cross drilled and slotted rotors.
Click here to visit my CarDomain page
Old 11-19-2004, 11:42 AM
Yes, I am from Canada. How would I find the sensor if it's dislodged. Do you think there would be an easier way to find it then taking the dash apart?
Old 11-20-2004, 01:43 AM
This is the info I found from searching, quoted from other people.
"93-96 cars have the sensor mounted in that round thingie thing in the dash to the right of the defroster vents"
"My T/A has got one. It's a circle thing that is on top of the dash on the passenger side. Above the airbag and a bit to the right and below the defrost vent."
"A couple of things, 93-96 cars have the sensor mounted in that round thingie thing in the dash to the right of the defroster vents, that is easily accessible, 97-up cars have the sensor buried down in the defroster vents, a real biotch to get to."
Since I don't have this on my car I can't take a picture of it or anything but if you find it you might want to get a bright flashlight and shine it into the sensor and see if it makes the lights turn off, if not I'd replace the sensor.
Hope this helps.
Old 11-21-2004, 10:45 PM
hotrod_chevyz's Avatar
hotrod_chevyz hotrod_chevyz is offline
Replace the sensor it has flown south for the winter
Old 11-22-2004, 11:01 PM
well i got a 95 and i dont have one.....
to answere your quesiton, just pull up the top dash peice. it is velcrowed on thier
then put the sensor back in place and go with it
95 TA - fast
92 240 - fun
Old 11-29-2004, 09:48 AM
Thanks guys. I was able to find it by popping up the vent. The headlights are again working.
