Old 11-15-2004, 02:57 PM
olddawg olddawg is offline
1990 LeSabre Steering Problem
My 1990 LeSabre has develpoed an oversteer proble that only happens sometimes. I've replaced the tie-rod ends and thes did not help. I'm kinda' at my wits end. Any suggestions or thoughts? Thanks
Old 11-16-2004, 12:44 PM
Lasota Lasota is offline
Re: 1990 LeSabre Steering Problem
There are a few more things that can be checked, ball joints, front struts, sidewalls of the tires for blemishes, tire pressure, anti sway bar mounts, upper strut mounts.
Good luck.
Old 11-16-2004, 08:32 PM
I've checked most of those things out. I'm thinking that it could be a valve in the rack and pinion.
Old 11-17-2004, 11:52 AM
sallisonbrown sallisonbrown is offline
Have you checked your power steering pump? Make sure the fluid level is correct, or even suck out the old fluid and replace it with new. Occasionally the valves will stick on old, thick fluid.
Old 11-19-2004, 07:39 PM
piewagn's Avatar
piewagn piewagn is offline
It sound like your rack tensioner may be too tight. Loosen the lock nut & loosen the plug cap 1/2 to flat. Don't forget to tighten the lock nut.
Old 11-19-2004, 07:41 PM
piewagn's Avatar
Sorry, that's one half to one full flat.
