Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 11-15-2004, 02:15 PM
nosboyracing nosboyracing is offline
93 Intrepid wont run????
1993 Intrepid 3.3 litre. Cranks, but won't start.. No fuel pump pressure.. I checked the fuel pump fuse in the fuse block and no 12+. As a matter of fact, the whole bottom row of fuses have no power.. I jumped a wire from the dome light fuse to the fuel pump, and the car ran. I drove it home from the north side.. if you shut the key off while the fuel pump circuit is jumped, the car still runs... the dash gauges are also inoperative.. I tested all of the big fuses under the hood and they were all O.K>.. Maybe an ignition switch problem or a break in the bulkhead??? PLEASE HELP Thnaks,, Gary Oles
Old 11-16-2004, 11:34 AM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: 93 Intrepid wont run????
At first, it sounded like a cam sensor problem. Check all your electrical connectors going to and from the firewall to see if they're in nice & snug. Chances are you have a loose connection somewhere.
