Old 11-15-2004, 12:36 PM
SSAV SSAV is offline
no spark at plugs
we changed out broken 305 to a 350 in an 85 gmc.after installing new cap,rotor,coil and even another distributor we still do not have any spark to plugs.i have checked all ground wires and retighten all connections. we have 12v to distributor and 9v while cranking.any ideas?
Old 11-15-2004, 03:59 PM
LT1 Kayker's Avatar
LT1 Kayker LT1 Kayker is offline
Send a message via AIM to LT1 Kayker Send a message via Yahoo to LT1 Kayker
Make sure the rotor is pointed at the #1 cylinder while its at TDC, and installed correctly. #1 cylinder should be the front one on the right side as if your looking under the hood, standing in front of the car. That is if its an 80's Chevy SB 350.
Since your getting volts to the distributor that really only leaves the rotor, cap, wires, or plugs that could be wrong. Is your primary coil at 2-3 ohms resistance as well, and working? The same thing happend to my truck and it was because the coil was shot. I don't know what else to suggest other than those possible problems. It can't be much or a big problem since the distributor is getting volts. Good luck with that.
89 Chevy C1500 - Over 305,000 miles on her but still going strong.
Cut off cat/straight pipe.
Flo-Pro muffler. (Flowmaster soon)
Dual 3" tips.
custom intake.
chrome valve covers.
uhhh and im poor so thats all haha.
Friggin truck costs more to keep alive than I do. (4ishMPG no joke)
Wait, let me get this straight...Your honda has 1.6 liters, but my bottle of Mountain Dew has 2!?
Old 11-15-2004, 06:57 PM
broughy84's Avatar
broughy84 broughy84 is offline
Re: no spark at plugs
i take it you are using a good ole hei ignition system. sounds like the module inside the cap is bad. remember the coil is self contained in thi setup. try a new mod.
Matthew Brough
1997 Geo Prizm -- 301,000 miles
2000 Honda Accord -- 225,000 miles
2004 GMC Yukon XL -- 223,000 miles
1987 Jeep Comanche -- 116,000 miles
Old 11-17-2004, 12:37 AM
Faze2183 Faze2183 is offline
Send a message via AIM to Faze2183 Send a message via Yahoo to Faze2183
i was about to say the coil pack or ign system, those things have a rep for rustin up and fauling up and not send any spark
Old 11-17-2004, 08:21 AM
thanks for all of your help. the esc unit was bad so i wired around it and now have spark.
