Go Back   Automotive Forums Car Chat > Fabrication & Tools > Fiberglassing
Fiberglassing Fiberglasssing explained and the proper techniques on working on a fiberglass project.
Old 11-15-2004, 11:28 AM
floydamus floydamus is offline
Plexiglass And Lexan.
well im think if i member right thers a way uou can bend this. seems liek ive seen it done with a torch applying heat from a distance to make it bend. right or wrong ?
Old 11-15-2004, 02:28 PM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Re: Plexiglass And Lexan.
You can use a propane torch but you have to be real carefull because it will bubble very easy. I usually use a heatgun, its alot easyer to work with and safer, although it does take longer because it takes he plastic longer to get hot enough to bend.
Old 11-15-2004, 10:12 PM
aight thanks . i was thinking i membered seeing that done. just wanted to make sure
Old 11-17-2004, 06:41 PM
johnny2quick johnny2quick is offline
you should practice first. plexi is only successfully bent at certain temps, so you want to make sure that you have the right temps before you start your bending.
Eclipse project: 420a/fwd to 4g63t/awd conversion
looking for 1st gen 6-bolt/4-bolt awd parts
and all other awd parts
[email protected] if you have any for sale
Old 11-17-2004, 11:48 PM
ty for the info. i shoudl start soem fiberglassin shortly. then im goign to make some curved peices of plexi to cover soem leds and neons
Old 11-26-2004, 12:11 AM
s14tilo's Avatar
s14tilo s14tilo is offline
Send a message via MSN to s14tilo
what is the temperature the plexi has to be around to bend?
Old 11-26-2004, 12:21 AM
Forunn Daberator
Depends on the thickness, you can heat 1/8" thick in an oven at 200 for about 10 minutes and it becomes plyable.
