Old 11-15-2004, 10:45 AM
PArabbit PArabbit is offline
95 Park Ave HVAC Blend Door Location
Help! Have a 95 Park Ave with dual climate control. I'm having trouble with getting enough heat out on driver side.
It wants to be consistently less than what's available on passenger side, but the passenger side blend assembly gets hot to the touch, so heat is available. I just can't seem to get it much of it out on driver's side.
Replaced blend door actuator successfully on passenger side behind glove box last year. Now I need to find the master air blend door and actuator for the driver side. Any suggestions where to look?
Climate control light NOT flashing, and passenger side hotter/colder function works okay.
Thanks!
Old 11-16-2004, 06:38 PM
Jed Rule Jed Rule is offline
Re: 95 Park Ave HVAC Blend Door Location
The driver air mix valve actuator is mounted inside the HVAC programmer and operates the driver air mix valve. You would have to remove the programmer and open the programmer case.
Old 11-17-2004, 09:17 AM
Re: Re: 95 Park Ave HVAC Blend Door Location
Thanks for the reply!
The passenger side actuator that I replaced last year was behind the glove box, mounted on top of the HVAC programmer. Are you saying that the driver side actuator is mounted INSIDE the programmer enclosure?
Old 11-19-2004, 05:05 PM
The passenger side is actually on top of the air mix box. The driver side actuator lever extends out the bottom of the programmer.
