Old 11-15-2004, 10:32 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
H-beam rods with Speed Pro Pistons, wrist pins wont work...
I just bought these rods and pistons. I was assembling them and the wrist pins that came with the pistons arent floating. They need locks while the rods have bushings (meaning they are meant for a floating wrist pin.) Probly a very stupid question, but this wont work will it? Im gonna need to end up getting another set of new pistons. Has this ever happened to any one else? Its like the pistons need a C-clip to hold in the wrist pins but theres nothing there, they just slide in and out with a little effort. Also, does anyone have any D16 pistons with a ~9.5:1 compression that will handle a turbo? Either hyperutechtic or forged?
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 11-15-2004, 11:26 AM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
Re: H-beam rods with Speed Pro Pistons, wrist pins wont work...
I see you have the same problem I had with my eagle rods and CTR pistons.
you have 4 choices
1. sell the pistons buy new ones
2. sell the rods use OE
3. have the pistons machined to accept a c-clip
4. Fabricate a wrist pin retaining tool (like I did)
how I did it is I used a threaded rod, 4 nuts, 2 washers and some permanent thread lock.
cut the threaded rod to be 2mm (or less if possible) shorter then the pistons. you place 1 nut at each end at so they are flush with the opening of the wrist pin hole. place a large washer on the rod (may be needed to be trimmed to fit flush) and tighten with an other nut.
-n|n-------n|n-
this way the pressure is exerted on the nuts not the piston itself to bend it out of shape.
once everything is the right size assemble everything with permanent thread lock.
trim sharp edges with a file or small grinder and assemble as normal.
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 11-15-2004, 11:32 AM
you got any pictures of that concoction? Do the threaded rods just hang there and shake all over when the pistons are going up and down? Im not too sure if I like this idea, although it is creative.
ZC stuff
Old 11-15-2004, 11:59 AM
Kunundrum's Avatar
no there is enough pressure against the pistons to keep the retainor in place, in my case the bolts I used fit inside the wrist pin and the pin kept if from moving... not sure how it's going to work... but I have a spare block in case shit hit the fan.
sorry no pics
Old 11-15-2004, 01:12 PM
Oh, you havent ran it like this yet? I think I might have found a set of SRP pistons for $150 though so thats cool.
ZC stuff
Old 11-16-2004, 09:08 AM
doug294 doug294 is offline
Send a message via AIM to doug294
Same thing happened to me. I just ended up buying some SRP pistons and selling the other ones. That was the easiest thing to do.
I get paid to read e-mails when I'm bored....are you bored?
http://hits4pay.com/members/index.cgi?doug684
