Old 11-15-2004, 07:57 AM
PruSucks PruSucks is offline
Send a message via AIM to PruSucks
Battery?
My car is having a hard time starting. I don't know if it's the battery or the cold weather setting in? It takes a lot of effort to turn over, but it ultimately does. The battery is an Interstate and still under warranty. Any suggestions/advice would be appreciated. Thanks!
Old 11-15-2004, 10:58 AM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
Re: Battery?
i doubt its the battery as long as the starter sounds normal. Its probably your injectors or spark plugs.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
Old 11-15-2004, 12:10 PM
nialusa nialusa is offline
Send a message via ICQ to nialusa Send a message via AIM to nialusa Send a message via MSN to nialusa Send a message via Yahoo to nialusa
Re: Battery?
If your starter is struggling to turn the engine over then maybe your alternator is on the way out and not charging the battery properly?? Try recharging your battery. Also check your starter motor out. What age is your car?
Old 11-15-2004, 12:16 PM
The car is a 1995 Saab. How do I check the starter?
Old 11-15-2004, 12:51 PM
Re: Battery?
Start be just giving it a basic checkover, just look to see if there are any signs of damage, oil leaking over it etc Try recharging the battery first, simple problems first then move onto the harder things once the simpler possible problems have been illiminated. If your confident at working on your car you can dismantle the starter motor and clean the pickups etc to make sure a good contact is being made but to be honest I doubt if there will be any problems there.
Old 11-15-2004, 01:04 PM
Battery is charged. I even tried jumping it w/ another car but it still won't start. Guess it's the starter?!
Old 11-15-2004, 09:57 PM
Kaszak Kaszak is offline
Re: Battery?
if it isnt the starter the thermostat could not be working properly. There are alot of things that can go wrong. if u cant figure it our urself u should have it looked at by a profesional.
P.S. nialusa nice celeca
Old 11-16-2004, 01:10 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Battery?
wait a minute is this a no start or a hard start?
hard start - check the battery voltage WHILE cranking should not be below 9.6 volts, check fuel pressure
no start - check for spark and fuel
Old 11-16-2004, 12:06 PM
Evil Result Evil Result is offline
Send a message via AIM to Evil Result
Does the car start up easily after the car has been warmed up?
I notice some times my starter has some trouble turning over my engine when things get cold outside when i start my car in the morning.
I disregard my perceived image in the persuit of knowledge.
