IBS brakes -- Please help
Hi guys, I've posted before put I guess you guys forgot about me. Anyway my follow up question was. I told the mechanic about your suggestion but he seems to think it has to be the pump b/c if it was hub bearings the noise would continue all the time progressively getting worse. The ABS light is intermittant and the noise seems to appear when car is cold. (I hope I am explaining this right. I tried to take notes!). He is suggesting flushing the brake fluid as a stopgap measure b/c he says the ABS pump would be $1000 for the part alone!! I can't afford that and would like to know if you think flushing would help. In the alternative, is this "hub assembly" thing a big deal and major expense?
Thank you!! Clueless1 Report Post | IP: Logged |
do the brakes feel any different? now does the noise sound like metal scratching metal? and sorry about the follow up
93 teg LS B20B![]() ACT Performance Flywheel AEM CAI DC Sports Stainless Steel Header G4 High Flow Cat GReddy MX Cat Back Exhaust Skunk2 Racing Chip Lots of interior goodies |
Re: IBS brakes -- Please help
I am sorry what was the situation again?
No brakes feel same and it does not sound like metal on metal. The one time a mechanic heard it, he said it sounded like a cable or a pump. To me, however, it sounded like chickens! Would replacing the brake fluid help? |
Did the pedal pulsate?
i have to ask too. do they pulsate when you depress them? b/c too me it seems if something was wrong with the brakes you would know when you use them.
Re: Re: IBS brakes -- Please help
Then why does the mechanic guy insist it is the ABS pump? He says there is nothing else on right side which is where the noise is coming from? I don't get it. |
if its an obdI have you done a self daignostic?
A.K.A. GOT WIDE darton 84mm MID's ls stroke 2.0l GS-R pnp head with full skunk2 pro series valve train and pro1 cams custom divided top mount w/garrett gt4094r not stoping till i hit 750hp to the wheels this aint your mom's car so DONT F***ING TOUCH IT |
If the pedal pulsates than it is doing its job, it means that the ABS system has been triggered and that is what happens when the abs system kicks in.
