Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 11-14-2004, 11:56 PM
mitech mitech is offline
'99 Stalls at idle
Hi all
I've been working on 99 with a 3.4L, auto trans,that stalls regularily at idle when at operating temp. The MIL is on with cde P0172 rich. Long term fuel trim is at -40 at idle but levels out at -5 at highway cruising. I've cleaned the maf, which is reading within specs, O2 are fluctuating bet 0.05 and .9 volts. No vacum leaks that I can find, fuel pressure is at spec with koeo but I can't check it with engine running.
Any ideas?
Old 11-15-2004, 08:17 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: '99 Stalls at idle
Leaking injector
Engine coolant temperature sensor <- First thing to check
Check spark in all cylinders
Old 11-18-2004, 08:57 PM
chachy6959 chachy6959 is offline
Mine (92 3.0L) was doing the same thing and I had the injectors cleaned and they found two vacuum leaks as well and it fixed the problem.
Old 11-26-2004, 12:52 AM
forest_grump forest_grump is offline
Originally Posted by mitech
Hi all
Any ideas?
Read where you stated that you had cleaned the AFM but what about the inside of throttle body where gunk builds up around throttle valve plate on inside......when it builds up there it will not allow enough air to pass by throttle plate which causes richened fuel mixture at idle which is always more noticable when engine is warmed up :o)
