Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 11-14-2004, 10:57 PM
gsxeclipse97 gsxeclipse97 is offline
Send a message via AIM to gsxeclipse97
2g throttle body
i just read that the throttle body in 2g is bigger than the one the 1g and the cyclone is this true it wasnt off of a offical site so i dont know if that is true? so if this is true that would mean i should keep my 2g t.b and just hook it up to my cyclone intake manifold? they said that it was a 60 mm t.b
Old 11-15-2004, 04:31 AM
kjewer1 kjewer1 is offline
AF - Advisor
Re: 2g throttle body
Is this turbo or non turbo? Please put car info in sig 2g turbo is 52mm, 1g turbo is 60mm. 1g NT is 60mm. No idea what 2g NT is.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
Old 11-15-2004, 10:44 AM
guitarXgeek's Avatar
guitarXgeek guitarXgeek is offline
Send a message via AIM to guitarXgeek
They may have been talking about the 2g throttle body elbow which connects the IC piping to the throttle body. The 2g elbow does flow a little better than the 1g.
95 GSX
DSMlink, "50 Trim", and track times coming VERY SOON!
Old 11-15-2004, 11:15 AM
sorry it was a 2g turbo he was talking about. can you hook the 2g t.b elbow up to the cyclone i.t.m is the t.b on the cyclone 60.mm also
Old 11-16-2004, 02:22 AM
AF - Advisor
cylcone is a waste of time unless you are really going to put the effort in to get all of the solnoids working with the jdm ecu. A lot of work for very little return. On a 2g head, just stick with the 2g manifold and port it to 60mm and use a 91-94 turbo TB.
Kevin Jewer
Old 11-16-2004, 10:40 AM
im planning on getting a 1g head and using it on that i dont think that it would even bolt up to the head that i have on mine and the one that i bought has all the parts to make it work i just need the head for it
Old 11-16-2004, 10:58 AM
doesnt the second set of runners run off the vacum line so once you hit boost the other set opens up?
Old 11-16-2004, 12:13 PM
well i just did some reading on this manifold it seems that this guy was making 5psi at 2500 rpms with a 16g turbo im still in vacum at 2500 with a t25 i dont think that i make 5psi untill 3500.
Old 11-16-2004, 03:30 PM
o*HeR()'s Avatar
o*HeR() o*HeR() is offline
Banned
Re: Re: 2g throttle body
no i think you have to use the 1g t.b elbow for the cyclone
Old 11-16-2004, 10:13 PM
i read that you can use the 2g elbow on the 1g so i figure that you can use it on the cyclone
Old 11-18-2004, 05:58 AM
AF - Advisor
Re: Re: Re: 2g throttle body
The TB elbow and manifold are unrelated. I don't mean to offend you, and I hope I dont, but I still cant figure out where you are getting your info from, 90% of it is wrong.
Kevin Jewer
Old 11-19-2004, 03:25 AM
i got that off of v-faq and it shows pitcures of it installed on a 1g eclipse. I know that the e.b. wont help me but i do need it to hook up to the stock piping on the car
Old 11-19-2004, 03:29 AM
do you know where i can find a jdm ecu? and here is the site where i found the guy with a galant vr4 with the cyclone installed
http://web.ask.com/redir?bpg=http%3a...nip&Complete=1
