Old 11-14-2004, 10:27 PM
Hawaii Hawaii is offline
pushing stock turbos to limits
Sorry if this one is in the faq but i couldent find it. Any way,what is the highest psi the stock turbos can push?
92VR-4
APEXi safc2
APEXi turbo timer
APEXi intake
Old 11-15-2004, 01:20 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: pushing stock turbos to limits
I think they will peak around 20 and quickly drop off. However, do not just turn up the boost.
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-15-2004, 01:57 AM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
I seem to remember hearing that they blow nothing but hot air after like 15.
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-15-2004, 02:34 AM
They are out of the efecentcy after aprox 15psi, however your car will keep going faster the more boost your push, which has been proven many times.
Old 11-15-2004, 08:13 AM
Gateway's Avatar
Gateway Gateway is offline
usually you want to max out the stock turbos at 14.5 psi. at 15 your stock y pipe will get blown off.
'92 3000GT VR4
Current Mods:
K&N FIPK
RPS Streetmax clutch
Rebuilt tranny
Free Boost Mod
Maximal Performance Solid Motor Mounts
Pictures and Videos of my car
Got a question about your auto insurance? I'm an insurance agent, ask away.
Old 11-15-2004, 02:13 PM
It should hold a lot higher than that, if yours is blowing off at 15 you need to tighten the bitch down.
Old 11-15-2004, 07:53 PM
na i got all the parts such as injectors and new metal y pipe but i just wanted to know what the best i should run the stock turbos at without having to get them redone or buy new ones
92VR-4
APEXi safc2
APEXi turbo timer
APEXi intake
Old 11-15-2004, 08:13 PM
Gateway's Avatar
run them at 14.5 psi until you get upgraded turbos
'92 3000GT VR4
Current Mods:
K&N FIPK
Rebuilt tranny
Free Boost Mod
