Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse 2000+
Old 11-14-2004, 10:05 PM
crazy_ugly_coyote crazy_ugly_coyote is offline
Banned
Send a message via AIM to crazy_ugly_coyote
Lightbulb Performance Cams
Has anybody heard of any performance cams for the 4 cyl? also, has anybody thought of taking the head off the RalliArt lancer and throwing it on our engine? it has the MIVEC head, and i beliee it is DOHC. i f anybody knows of where i can get one reletively cheeap i will throw it on my car. i know the RalliArt Lancer dyno's at 165 crank HP. seems like the most effective way of raising hp, without throwing out lots of cash.
Old 11-15-2004, 08:57 AM
johnnyBgood johnnyBgood is offline
Send a message via AIM to johnnyBgood
Re: Performance Cams
That would be alot of money, as the ECU would not know what to do with the extra cam. So you would need a piggyback or full standalone to compensate for the extra cam. Plus, the Fed Spec eclipses (00-01) are rated for 154hp at the crank, so you would be spending alot of money just to get DOHC and 11hp at the crank, which is about 8-9whp. Not worth it.
Now for performance cams, there is a company called RPW out of Australia, with an importer named Vision Imports which sells performance camshafts. But the stock cam is a very well made cam, and not alot of power can be made by simply switching cams. Add boost to about 11-12psi, then add a Stage 2 turbo cam, and then you will see the difference.
