Old 11-14-2004, 09:56 PM
Thourun's Avatar
Thourun Thourun is offline
Send a message via AIM to Thourun
FMIC wow!
Omg look at this FMIC, its HUGE! And it completely eliminates the Y pipe.
http://www.pitroadm.com/PitroadM-HP-E/newframe3.htm
And only $2,353! Pit road M makes great stuff. So what are the advantages of a FMIC (other than the obvious great look) and how moded would and engine be for it to become a good upgrade?
1995 3000GT VR-4
Installed: ESP front precat eliminating downpipe, test pipe, RF-1008 K&N, Dejon tool Y pipe, 1G DSM BOV, MSD wires, Guted rear pre cat, ISSPRO EV Marine boost gauge, IPO MBC, EGR blockoffs, Palm m515 dataloger setup, NGK iridium plugs, SPEC stage II clutch 500ft/lb, 5300k HID plug and play setup.
Soon:Topline Engineering ground wires.
Old 11-14-2004, 11:13 PM
StealthModifier StealthModifier is offline
Re: FMIC wow!
what does FMIC?? is that fuel management or somethin?
Old 11-15-2004, 12:34 AM
93PearlVR-4 93PearlVR-4 is offline
Send a message via AIM to 93PearlVR-4
Re: FMIC wow!
Front Mount InterCooler I think you can notice some gains no matter what, but unless you have a lot of mods done you would be better off with just some dsm's
Old 11-15-2004, 12:59 AM
Thourun's Avatar
Re: FMIC wow!
They're so expensive for the VR4, i've seen Ones for civics selling for like 500 pipes and all.
1995 3000GT VR-4
Old 11-15-2004, 01:34 AM
talskinyguy talskinyguy is offline
Send a message via AIM to talskinyguy
Re: FMIC wow!
The civic ones are also a lot smaller have only have 1 turbo, so there is about 1/2 the piping.
A FMIC will drop your intake temps, which will allow you to make more power at the same boost, and you will be able to turn your boost up a little more. Lots of people say that our stock ones are "good enough" until you get heavily modded, but if you compair flow numbers you see a huge difference over stock. For example, the stock IC's flow 133CFM each, grand total of 266CFM. My FMIC Flows 1200CFM at the same presure drop, and cools the air to around 80-100* in the summer. Stock temps are generally around 130-140.
Not all FMIC's are 2-3 grand, Mine was 1100, and now they sell for around 1300.
http://www.geocities.com/speedpartsrus/3000gt.html
A few "bolt on" mods, a couple "cut, smash, hammer, weld, etc" mods, and a couple "why the hell do I need this/what the hell is this" weight reductions.
Old 11-15-2004, 02:03 AM
Thourun's Avatar
Re: FMIC wow!
Wow thats great to know, do you have upgraded turbos? I forget lol, hard to remember names on here sometimes and you don't post as much as some like myself [/postwhore]. Can't wait to get myself a VR4.
Edit: After looking at the site I am wondering wheather the 14" has both turbos plug directally into the IC, looks like it but not shure. And does that benifit the system or is it just a different style?
1995 3000GT VR-4
Old 11-15-2004, 02:12 AM
Re: FMIC wow!
I think my car is the most upgraded on this forum
Mod list time
AEM EMS with 3.5Bar MAP, GM IAT, and dual wideband
880CC injectors
IPO's Dual pump Dual feed Fuel system
Titan Bending(formerly JAC) TD05 manifolds and o2 pipes
14B Turbos with Bullseye Power Turbine housings
ATR Downpipe, Modded to fit
Custom PVC intake with the biggest diesel truck filter I could find, soon to be stainless steel because the PVC kept melting
14x24x3 FMIC, mostly custom piping, still in the process of making the rest.
5Zigen FN01RC 17x9 wrapped in toyo Proxy T1-S's
Tien HA coil overs
Solid steel motor mounts
No A/C
No Idler Pullys
Soon to be no Cruse control
Custom fiberglass sub box / 2 seat conversion in the making right now.
99 front end
VLS hinges - For sale 1300 shipped
Custom dyed carpet and door panels from charcol grey to back(looks much better now)
Short throw shifter
Im sure im missing some little stuff in there.
Old 11-15-2004, 02:15 AM
Re: FMIC wow!
each turbo has its own pipe all the way to the IC, most people say there is no benifit, but the guy who makes them says there is potential for this to work better, but no one says thats its worse than merging before the IC.
My oppinion is that he hasnt made a TT kit before and didnt want to merge to 2" pipes into a 3" pipe. Doesnt matter much to me.
Old 11-15-2004, 02:26 AM
Thourun's Avatar
Re: FMIC wow!
So wait the kit you bought from this guy didn't have all the piping included?
1995 3000GT VR-4
Old 11-15-2004, 02:28 AM
Re: FMIC wow!
It has all the piping for a TD04 car, TD05's fit differently, and I didnt like the way the TD05 kit went with the FMIC kit, so I cut all the piping to hell and am welding it back together how I see fit.
Old 11-15-2004, 02:36 AM
Thourun's Avatar
Re: FMIC wow!
Ahh now I get it, so whens the car going to be "finished" lol? Can you drive it now? Never thought that having different turbos would make that big a difference but then again they're totaly different in size and housings and all I think.
1995 3000GT VR-4
Old 11-15-2004, 03:02 AM
Re: FMIC wow!
I was driving for a while, but its apart for the winter so I can finish the small stuff that I just didnt want to do because it was nice out. Should be back together when it warms up, until then Ill leave it apart to fix/customize all the stuff I can.
For turbo differences, the stock front points down and the rear points up, TD05's are the exact opposite.
Old 11-15-2004, 08:49 PM
Knight2040's Avatar
Knight2040 Knight2040 is offline
Send a message via AIM to Knight2040
Re: FMIC wow!
how do FMICs effect engine cooling? i mean your radiator is already behind the AC condenser, then you stick a highly restrictive intercooler in the way, thats what i'v always wondered about.
1991 Mitsubishi 3000GT VR4 Twin Turbo- Forged Ross Pistons,Forged Crank,Forged and Shotpeened Rods,Stillin DP,K&N FIPK,Greddy Type-RS BOV,Magnacor Wires,Aluminum Y-Pipe,EGR Blocked,All Gutted Cats,Greddy Turbo Timer,Blitz Boost Guage,Autometer A\F Guage,Solid Shift Bushings,Red Top Batt,ACT 6 Puck Clutch,Free Boost Mod,99 Front End Conversion
Old 11-15-2004, 09:10 PM
Igovert500's Avatar
blue + red light magnet
Re: FMIC wow!
talskinyguy, are you planning on running it at the track...I don't remember ever hearing times from you...
96 3000gt vr4
-K&N FIPK
-Proboost mbc
-Greddy type-s
-ATR downpipe
-no cats
Old 11-15-2004, 09:27 PM
Re: FMIC wow!
There is no way in hell I can pass tech right now, oil dripping from my turbos, battery strapped down in the rear of the car, not in a box.
As far as cooling, my car sits riht at 180 when driving and only goes up to 190 when im still.
