Go Back   Automotive Forums Car Chat > Nissan > 240Z | 260Z| 280Z | 300ZX (Past Z Cars)
240Z | 260Z| 280Z | 300ZX (Past Z Cars) The original Z cars - ones that started it all.
Old 11-14-2004, 08:08 PM
rendertrust's Avatar
rendertrust rendertrust is offline
suggestions on diy job
well my seatbelt is a little twisted, it had 2 twists but then i moved one to the other side of the barrier, it still looks ugly
do you guys think i should take apart the door and fix the seat belt? or will i more than likely never be able to fix it myself without screwing something up ?
Old 11-14-2004, 09:18 PM
freakonaleash1187's Avatar
freakonaleash1187 freakonaleash1187 is offline
Send a message via AIM to freakonaleash1187 Send a message via MSN to freakonaleash1187
Re: suggestions on diy job
well, interior parts are one of the easiest things to work on on a car. so it shouldn't be that hard.
-Jared
ZedEx Crew Member #2
Old 11-14-2004, 09:35 PM
k3smostwanted's Avatar
k3smostwanted k3smostwanted is offline
Z Cars Fanatic
Send a message via AIM to k3smostwanted
yeah eventhough, the 300zx door is one of the harder doors to take apart, it isnt hard. just know where all the bolts are and make sure you dont break any of the plastic clasps. i will look for a write-up with pics to show you whre the bolts are. there is about 10-12 screw and bolts that need to be removed. good luck...
ZedEx Crew Member #4
Old 11-15-2004, 06:45 AM
oh, and another thing, if you don't know already, whever putting plastic pieces back together, never tighten the screws all the way, it could crack the plastic.
-Jared
Old 11-15-2004, 08:13 PM
i need the plastic that goes under the front of the car !! anybody got some extra or know where i can find it
Old 11-15-2004, 08:20 PM
Z Cars Fanatic
you will probably have to order that through nissan or a body shop or go to a junk yard and see of any of them still have it in tack...
Old 11-15-2004, 09:15 PM
neogenesis neogenesis is offline
I always have a problem sliding it back into place. The interior part of the door is a bit iffy to snap into the window tabs...for me anyways
Old 11-15-2004, 09:53 PM
you can get the splash guards that are under the car from here http://conceptzperformance.com/Cart/...569.76.137.188
-Jared
Old 11-16-2004, 01:15 AM
DeleriousZ's Avatar
DeleriousZ DeleriousZ is offline
Send a message via MSN to DeleriousZ
ouch... that's quite the chunk of change for a piece of plastic... just get some cardboard.. completely cover it with duct tape, then duct tape it to the underside of the car.... instant splashguard
ZedEx Crew Member #6
1988 300zx turbo 5spd. 3" mandrel exhaust, filter, afco rad, e-fan, poly engine mounts, mbc at 8.5 psi, turboxs rfl-h bov, gutted plenum, etc.
blown turbo, under construction.. gt35 coming.
Old 11-16-2004, 01:28 AM
Z Cars Fanatic
lol...after almost 15 years of wear and tear, mine were starting to tear away from the bolts. so i just poked new hole through them and used zip-ties. the zip-ties hold that stuff up there better than the few 10mm bolts.
Old 11-16-2004, 06:39 AM
you should see my splash gaurd. it has about 10 zip ties in it. i was getting on the interstate one day and my friend tells me that i better hit a 100 by the end of the ramp. so i do and just about when i am going to get over, i look ahead and there is an object in the road. i hit it and it made a big "thump" noise, it was part of a semi tire. freaking ripped my splash gaurd all up.
-Jared
Old 11-16-2004, 07:19 AM
damn thats too much for plastic hmm it seems i even need one of the fender wells, thats what that plastic is under the fender right
prices are rediculous i think they probly even have a j-spec splash gaurd which makes the car more aerodynamic and looks cool while drifting lol j/k but with my 50$ im getting some cheap 6.5 speakers on ebay, my car only has 2 right now. one on each door
Old 11-16-2004, 10:55 AM
rZ12's Avatar
rZ12 rZ12 is offline
Isn't it usually pretty easy to fix twists in a seatbelt? Just fiddle around with folding and pulling the belt through the eye on the clasp.. Worked in my car.. (Not a 300ZX)
Old 11-16-2004, 02:59 PM
well not in my case, i already folded it once but there is 2 twists, this wont do anything except make the twists on the other side of the clamp, right now theres one twist on the back and on twist on the front
i hope taking off the door will fix it, im going to work on it this weekend i dont even know what im going to do much less how to do it but i will try to do something
Old 11-16-2004, 03:10 PM
Z Cars Fanatic
http://www.carstereohelp.com/stereor...s300zxFSpk.htm
there is a tutorial on how to remove the door panel. also on that same website there is alot more stuff on how to take apart your dash, rear speakers. alot of goodies.
also, one mroe thing. if you want to take the door panel completely off, the top part that holds your seat belt at its peak. there is a cap over that. pop that cap off with a small flat head, then there is a 14mm(?) bolt right there. unscrew that and that pillar should pop off.
good luck!!! kinda scary the first time because if the door has never been apart, your afraid to pry so hard or maybe your missing something and you dont want to break nothing. but once the first time is over, its really easy from there. i have installed lots of car stereos and by far, i hate the door panels with like 2 small screws holding the whole door together. because after so many times of taking that off. it never goes back together how its supposed to.
