Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 11-14-2004, 07:52 PM
crossman305 crossman305 is offline
87 caprice with a few problems
I have a 87 caprice with weird problem. Currently when i start up the car, let it warm up and drive it i have bad octane knock, it goes away after the car gets really warm. IN warm weather this doesnt happen I replaces the plug wires, rebuild the carb, new egr valve, it ran with out a problem for a few days after the egr valve was replaced. What can i do to fix this problem. ?
Old 11-16-2004, 07:12 PM
PeteA216's Avatar
PeteA216 PeteA216 is offline
Send a message via AIM to PeteA216
Re: 87 caprice with a few problems
Fouled plugs? How many miles on the engine?
Old 11-17-2004, 04:24 PM
its got 187000 miles, i have been trying to figuer out where the noise is comming from and partially the manifolds have holes causing some of the noise but still i get some octane knock, I can replace the plugs and see if that helps
thanks
Old 11-17-2004, 08:00 PM
TommySS TommySS is offline
You've got severe carbon build up. Get some SeaFoam from NAPA. Fixed mine to the point I could switch from premium and run regular.
Old 11-18-2004, 05:47 AM
CD Smalley CD Smalley is offline
GM makes some stuff called Top Engine Cleaner that works great too. Get the aerosol version for best results I think.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 11-18-2004, 03:27 PM
HLandin's Avatar
HLandin HLandin is offline
Re: Re: 87 caprice with a few problems
How do you use it? Is it something you add to your gas, oil, or do you apply it directly after disassembling manifolds?
Old 11-18-2004, 04:57 PM
PeteA216's Avatar
I agree perfectly with TommySS, thats also why I assumes the plugs too. Also... I know this sounds wreckless and kinda dumb, but yesterday I tried toppin' out my '84 Caprice on the highway with my buddy following (my speedometer only goes to 85mph, so he measured my speed w/ his car) I got up to a little over 110 mph, then I had ta slow down because of traffic. ANYWAY, while I had the car floored, my buddy said that there were a lot of black puffs of smoke and dark dust-type crap comin out of my exhaust. Since then I've only driven the car about 3 times, but now my rough idle and slight heasitation is completely gone. The car's never run this good. I've even noticed a little better accelleration. I'm assuming opening up the engine like that cleaned it out. Give it a try if you can find a safe place to do it.
Old people owned the car before, and it only has 60000 on it. Does anybody think that because of it being soft pedaled all its life, and having mostly city driving caused the engine ta buid up dirt and carbon?
Old 11-18-2004, 08:30 PM
Re: Re: Re: 87 caprice with a few problems
Get the car warm and let it idle. Removed the air cleaner assembly. Spray into the carb while using your spare hand to keep the car running, just barely over idle. This stuff will try to make the engine stall. Just keep spraying until the can is empty. Then shut the car off and let it sit for 15-30 minutes. Then start it up and watch the smoke come out of the tailpipe. Best to keep the car at a high idle speed until the smoke stops.
That's it roughly. Read and follow the instructions on the can just to make sure.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 11-18-2004, 08:33 PM
HLandin's Avatar
How can you tell if you have severe carbon bill-up? What are the symtoms?
Old 11-18-2004, 08:41 PM
The car pings like crazy (even on premium), sluggish, poor mileage, etc.
Old 11-19-2004, 09:46 PM
HLandin's Avatar
Another thing, is this carbon build-up we're talking about found in the air cleaner or in the exhaust manifolds?
Old 11-24-2004, 04:44 PM
It's typically found in the heads (around the valves). The carbon absorbs gasoline, and heat, which keeps the cylinder hot (hence the ping and the eventual need for premium - except at some point even that won't help).
When I did my Seafoam treatment, I let the car sit overnight and THEN started it. WOW, it's great stuff.
PeteA216 presented a typical case (old people drove it easy), and the problem solved itself with a couple of high speed runs to blow the carbon out.
