Old 11-14-2004, 07:50 PM
i need help i need help is offline
Send a message via MSN to i need help
1991 camaro rs wont start
ok iv but new oxgen senser new cap roter disterbeter plug wires pluges new but it aces like it going to start but wont could it be the ecm or vss senser can any body help bring it back or time for a new motor it only has 121k but never no
thanks
Old 11-15-2004, 03:33 PM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: 1991 camaro rs wont start
have you tried turning the key?
Old 11-15-2004, 06:05 PM
tacoma man.'s Avatar
tacoma man. tacoma man. is offline
Send a message via Yahoo to tacoma man.
geno, what will we do with you......
dude, can you hear the fuel pump kick in when you turn the key to the onn position? if so your fuel pump is ok. another thing it could be your ecm fuse, my brother ecm fuse blowed in his trans am and it wouldnt fire will cranking. we replced it and it started right up.
Old 11-15-2004, 08:04 PM
ill look at that in morning thank for help ill let you know
Old 11-16-2004, 10:58 PM
ok it not a fuse thank tho
Old 11-17-2004, 01:27 PM
89IROC&RS's Avatar
89IROC&RS 89IROC&RS is offline
did you ever remove the distributor?
are you sure you put the spark plug wires on the right way?
are all your electronic connectors to the distributor connected?
have you checked fuel pressure?
Chevrolet Camaro - I enjoy beating the hell out of people
http://www.automotiveforums.com/vbulletin/showthread.php?t=68052
Old 11-17-2004, 07:50 PM
it has fule pressure is at 40 pluge wires wher done by my dad and me 1 at a time the distributor was but back in the the same way it came out thanks tho might be time to go to the shop
Old 11-17-2004, 11:24 PM
nlghtcrawler nlghtcrawler is offline
Send a message via AIM to nlghtcrawler Send a message via MSN to nlghtcrawler Send a message via Yahoo to nlghtcrawler
is it ur security system? does ur security light stay on when u turn the key to the "on" position? if so u might have a vats problem.
Old 11-17-2004, 11:35 PM
89IROC&RS's Avatar
what does it do when its trying to start? does it just crank? or does it start, and die, fire a few times, die, that kinda thing. ?
Old 11-18-2004, 07:06 PM
it will crank but not start the security light flashis 2 time then gos out when it is crankin it sounds like its going to start but just keeps crankin thans
Old 11-18-2004, 07:33 PM
89IROC&RS's Avatar
run it for codes, do you know how?
Old 11-18-2004, 08:23 PM
Genopsyde's Avatar
The President
$20 says it's ignition, probably coil.
Old 11-19-2004, 12:54 AM
y2icon's Avatar
y2icon y2icon is offline
Send a message via AIM to y2icon Send a message via Yahoo to y2icon
i need help if you figure it out plz tell me lol have almost the same problem and iroc's been helping me
Nitrous= the car equivalent of a penis pump
Old 11-20-2004, 01:49 PM
im going to go buy a coil and see if that is it y2icon ill let you no if it works or when it is thanks
Old 11-20-2004, 02:33 PM
ok it not a coil and i run it for codes and it come up code 12 what is pass thanks
