Old 11-14-2004, 08:48 PM
mtb020184 mtb020184 is offline
Send a message via AIM to mtb020184 Send a message via Yahoo to mtb020184
89 Camaro Transmission Clunk
I just picked up this car, I got it because of the condition of the body, not the mechanical condition.
Unfortunately it has a problem that I can’t seem to find the awful clunking noise it is making. It really slams, the whole car jumps, when you are on pavement and you hit the gas hard, or when your accelerating fast, and it shifts. If you’re on lose stones, the tires break lose and it doesn’t make the noise.
I originally was thing U joints, so I changes them, and also changed the seal in the differential, put new oil in the diff, and checked that all out, and everything appeared find. There is plenty of fluid in the trans, and the flywheel bolts appear to be tight also. Motor mounts are also fine. The car does seem to accelerate slowly too, I think that might just be a plugged cat converter. Anyone have any Ideas?
Old 11-14-2004, 09:12 PM
Dober89 Dober89 is offline
Re: 89 Camaro Transmission Clunk
Could be the torque arm mount has broken. Mines toasted and it does the same thing when shifting into 2nd gear.
Old 11-15-2004, 05:12 PM
Well the problem is hopefully solved, we put a jack on the trans to see if it would move, like the torque bar was broke, and a problem was found, the transmission mount was broke, I’ll probably get the new one in it tomorrow, thanks for the idea
Old 03-04-2006, 01:12 AM
Tuffdrvr88 Tuffdrvr88 is offline
Send a message via Yahoo to Tuffdrvr88
check differential and tranny mounts
Old 03-04-2006, 01:18 AM
bag91's Avatar
bag91 bag91 is offline
that would definately be clunking
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
