Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 11-14-2004, 08:14 PM
JHZR2 JHZR2 is offline
E30 water directly under driver's seat
My car is a 91 318i 4dr, 5sp, E30 model.
For the past short while, Ive been having some trouble with water. It first was noticed in the rear drivers footwell (about an inch there, none elsewhere). I verified that all the drains (sunroof, rockers and elephant trunk) were operating properly. I dried it all out, traced routes of entry, pulled up carpet, poked around everywhere possible, but never got anywhere.
No more water came in, so I thought that maybe the few acorns, etc that I pulled from the elephant trunk was the solution.
The car has been closed up for the past few weeks when I was travelling. Tonight I went out, and felt around, out of curiosity. Well, there was dampness again (not the inch of water that was there previously, but I could feel that it was wet in the padding).
The only spot that it is wet, and apparrently where the water is coming from is directly under the drivers seat. Nothing in the drivers footwell, nothing in the rear footwell.
I dont know where else to look... Ive shecked the heater core, AC evaporator drains, door seals, window seals, sunroof, rockers, etc., etc., etc.
Any ideas???
Thanks so much for any help you can give.
JMH
Old 11-15-2004, 11:02 AM
Celsdogg's Avatar
Celsdogg Celsdogg is offline
Re: E30 water directly under driver's seat
you might want to check if there are any rust on the underside. . . thats the last thing i can think of. . .
Current:
1990 BMW E30 325i
2004 Subaru Legacy
2008 Toyota Sienna LE
Retired:
1978 Cadillac Fleetwood Brougham
1990 Volkswagen Jetta GL
1991 BMW E30 325i
2001 Honda Odyssey EX
Old 11-15-2004, 08:43 PM
fortunately there is no rust...
Thanks,
JMH
Old 11-16-2004, 10:52 PM
catman3 catman3 is offline
My friend had some experience when there is the leakage of rubber seal in the rear window, pls check
Old 11-16-2004, 11:00 PM
No reason to think it was this, based upon the fact that I sprayed the rear window seal and saw no water in the trunk or coming from under the rear seat.
Can you suggest a better way to verify that it isnt leaking? Id greatly appreciate it, as it seems that the areas behind the window seal are hard to get to...
Did the water in your friends car end up in the rear wheelwell or under the front seats?
Thanks very much,
JMH
Old 11-17-2004, 11:09 AM
323imankiks's Avatar
323imankiks 323imankiks is offline
Did you check the vaper barrior inside your door panels? these panels must be water tight otherwise you will have leaks. I replaced mine because one side had holes in it other side i just replace to be sure these are sealed with butyl tape i think they use this stuff for windshields its a black rope thats sticky but can also be removed when you need to service anthing inside the door or you could use silicone i guess to seal it up. take your door panel off and look at your vaper barrior
"What happens here stays here" LAS VEGAS
Old 11-17-2004, 08:48 PM
How did you check the seal rubber portion? I suggest to use some tissue. Put them around or just behind the sealing portion, then you spray and leave them for a moment. Wherever the door seal, rear door seal or any potential path..
Old 12-05-2004, 10:16 AM
Celsdogg's Avatar
i think this is what it might be:
http://www.bmwe30.net/cgi-bin/datacg...000&Section=00
Current:
1990 BMW E30 325i
2004 Subaru Legacy
Retired:
1991 BMW E30 325i
Old 12-06-2004, 10:58 PM
Jim Beamer Jim Beamer is offline
Question
Is it possible that you're heater hoses are leaking? Is it Swithed to Warm When you leave it sittting? Just A quick thought.
